Toolkit Contents
- Track Day Addict
Toolkit Contents
Just got an Aprilia tool kit off fleebay. Should there be a spanner which fits the back wheel axle nuts included?
- Track Day Addict
- Firestarter
- Twisted Firestarter
- Track Day Addict
Hi there
Page 28 of the handbook lists the tool kit contents. I can't copy it from the pdf but here is the link:
http://www.martinpoll.dk/diverse/SL%20M ... nglish.pdf
Andy
Andy
Yes the 32mm spanner is there but the one in the toolkit won't help much as that axle nut is torqued up very tight (120Nm) - you'd never get the leverage without a long extension arm.
The tool kit doesn't contain a 28mm for the front axle nut either - best to buy a 28mm and a 32mm socket to use with your socket set's long breaker arm or your torque wrench.
(at least, that's what I did).
Ah but if you only tighten up the axle with this spanner then you will be able to undo it with this spanner later. 120 Nm..... Pah!D-Rider wrote:Yes the 32mm spanner is there but the one in the toolkit won't help much as that axle nut is torqued up very tight (120Nm) - you'd never get the leverage without a long extension arm.
Actually I am joking ( a bit) there. I use the toolkit spanner with the toolkit extension and do it up tight but don't use a torque wrench. Otherwise I'd never get it undone again.
I AM NOT RECOMMENDING THIS TO ANYONE - just saying how it is for me
If you read this and buy my bike one day then bring a big spanner
Something I've always meant to do is go through my bikes' tool kits an replace everything with decent versions of the tools. Haven't managed it yet.
- Track Day Addict
