Modified Falcos on RSVR.net
Go on... lets get our most modified Falcos on here. D-Rider? Aladinsane? You up for it?
http://www.rsvr.net/shop/custom.asp?recid=30
I believe Siva and his Falco were at the '07 ClubAprilia day, don't recognise the other one.
siva's was there - and i saw the mileage the bike had done...
i guess I could post up to it - but my images would not look as good as MY BIKE gets ridden - often and hard!
also, and being totally honest here, my mods have, in the main, been driven by use ability - not by overt bling
I will email rsvr and see what they think
Mille Renegade exhausts
Mille Oil Tank
Mille Headers
Wavey disks all round
HEL Braided hoses - brakes and clutch
Skidmarx belly pan modified to fit the mille bits !
Power Commander 3
Double Bubble screen
WP rear shock
Handle Bwrs moved and secured above triple clamp
Brackets under screen to support garmin Zumo
Black rear lens with LED running lights
Mille rear swing arm
Scottoiler
all indicators changed to blister leds
VTR sidestand
Evo Airkit
Tail tidy from evo, then adapted to minimilise it some more :)
Heated grips with controls integrated to cockpit
Starcom and radio
performance - dyno says it's ok but does need to be set up properly - estimated to have 128 or so at the back wheel
still to be done.... well - I want to do something with the mirrors this year....
Oh - on average the bike does 6 000 miles a year, so apologies as it is not clean - I ride the bugger :)
Mille Oil Tank
Mille Headers
Power Commander 3
WP rear shock
Scottoiler
VTR sidestand
Evo Airkit
Starcom and radio
So let me think what I've got:
Installed:
Not mentioning luggage bits and pieces that need to be sorted before the summer ....
So, one way or another I've still a fair bit to do to get it finished ..... and as it's ridden virtually every day, it's not always easy to find opportunity ....
Installed:
- Fenda extenda
Meta Alarm
Scottoiler
HID dip beam with headlamp wiring mod
15t front sprocket
MPL clutch slave
Tuono front sprocket cover
Skidmarx bellypan
Heated grips (with electronic jiggery pokery I knocked up to turn them off when the ignition goes off and keep them off when you turn the ignition on again)
Navigation mount with navigation power supply
Double bubble screen
PCIII
Mille 2:1 exhaust with Fuel Hi-mount can
MilleR oil tank
Mille oil cooler
Smoked tail light lens (Greg-D)
LED tail lights (Nooj)
Gixer sidestand
Mille Swingarm
MilleR Ohlins shock
K&N filter
Quick release seat fasteners
- Head Up Display sender unit
- MilleR Ohlins Forks
Forged Oz wheels
LED indicators
- Side fairings to be bastardised from the unholy union of Falco & Mille Panels
Mille bellypan
Tail tidy
- Rear view camera
Airbox mod
i had 118 but with a crap map etc
a couple of other things have to be fitted and then I think it will be about the 128 line - and no, am not revealing what I have, but lets just say it is not just a bolt on thing
- FlyingKiwi
