Certificate of Conformity
Falcomille
#1 Post by Falcomille » Fri Jan 02, 2009 10:44 am
Good morning all - and Happy New Year to all as well....
Just sorting all my stuff out for registering the bike in France and I seem to be missing the Certificate of Conformity for the bike. Anyone got a spare one, or who can copy or point me towards an on-line copy?
Couldn't resist pushing the starter button yesterday and it started first time.... maybe this afternoon..... hey why not?
Peter
#2 Post by D-Rider » Fri Jan 02, 2009 11:01 am
Don't think we have those. Aren't they what Aprilia (or the dealer?) use when the first register a bike?
Hopefully someone will prove me wrong.
Syltiz
Chaos Merchant
#3 Post by Syltiz » Fri Jan 02, 2009 11:58 am
If its anything similar to my imported GSXR, Aprilia should be able to provide you this certificate for about £70
Falcomille
#4 Post by Falcomille » Fri Jan 02, 2009 12:11 pm
Sorry, I may be wrong, but when I looked in my car documentation, that had one in it, so I thought the bike might as well... OK off to Aprilia.com then.
#5 Post by mangocrazy » Fri Jan 02, 2009 12:18 pm
Hi Falcomille,
I recently had a long (online) char with Olivier, a French-born Falco owner, on the AF1 site and his views may not make happy reading for you. We basically hi-jacked a thread, and the interesting stuff starts at around post #24...
http://www.apriliaforum.com/forums/show ... 662&page=2
Olivier states that deristricted Falcos like ours are banned (i.e. ineligible) in France due them producing more than 106bhp. Personally if you're in France with your Falco I'd give it a go and see what happens, but be aware there may be problems. Knowing France, I suspect it will boil down to who you get to perform the inspection etc. , how good your French is and what mood they're in...
Hope this helps...
Syltiz
Chaos Merchant
#6 Post by Syltiz » Fri Jan 02, 2009 1:16 pm
Maybe reconnect the restrictor wire on the ECU which should allow you to get it dyno'd at 85bhp and avoid the potential problems the BHP cap presents.
Falcomille
#7 Post by Falcomille » Fri Jan 02, 2009 3:35 pm
mangocrazy wrote:Hi Falcomille,
Hope this helps...
Hi mango - thanks for that little snippet. Ouch, that looks like it might require a complete re-think. I'll have to speak with my neighbour and see if he can get any info out of the local Aprilia dealers. I have seen a Falco here, a really scruffy one from Toulouse on 31 plates, (red as well - sorry), so he managed to get one though the system, but litre sports bikes here are pretty rare, and the one's I've seen aren't restricted now.
I have managed to get out for an hour today and this thing is just SOOO adictive, so I don't want to part with it - equally, I don't necessarily want to ride back for an MOT every year. Bugger - what a predicament.
Falcomille
#8 Post by Falcomille » Fri Jan 02, 2009 4:54 pm
Just looking at Aprilia's Official French site, and at the spec of the RSVR in particular, it shows the max power at 106.8 cv, which I think translates to 106.8 bhp. If so, does that mean the Falco motor comes in under that? What is the standard official power of the Falco motor - is it 106? Perhaps Aprilia are shoving Falco motors into new RSVR's for France? Hmm. :smt017
#9 Post by D-Rider » Fri Jan 02, 2009 6:06 pm
My guess is that's with the airbox bung in place and the ecu wire un-snipped.
Reinstating to that level should not be a problem.
Oooh - wonder how necessary standard cans might be (hopefully not very important)
#10 Post by Kwackerz » Fri Jan 02, 2009 6:49 pm
FM, when you do eventually get it registered, can you do a write up on the trials and tribulations of registering a big derestricted Aprilia in France, please? May be useful for others to know the positives and negatives of the ordeal
:smt001
#11 Post by mangocrazy » Fri Jan 02, 2009 10:55 pm
Kwackerz wrote:FM, when you do eventually get it registered, can you do a write up on the trials and tribulations of registering a big derestricted Aprilia in France, please? May be useful for others to know the positives and negatives of the ordeal
:smt001
I will certainly be following your progress with avid interest. Falco + French roads = FUN!
If it was me I'd take advice and then give it a try anyway. If you don't ask, you don't get...
#12 Post by mangocrazy » Fri Jan 02, 2009 10:57 pm
Falcomille wrote:Just looking at Aprilia's Official French site, and at the spec of the RSVR in particular, it shows the max power at 106.8 cv, which I think translates to 106.8 bhp. If so, does that mean the Falco motor comes in under that? What is the standard official power of the Falco motor - is it 106? Perhaps Aprilia are shoving Falco motors into new RSVR's for France? Hmm. :smt017
Olivier was saying that the 'official' power limit on bikes in France is 78kw, which (apparently) translates as 106bhp. Does the Aprilia site give power in Kw?
Perhaps I should look myself... Ahem.
Just checked and quoted power output of the RSV-R is indeed 78kw. Now - are Aprilia just 'under-reporting' the power of the RSV-R or has it been nobbled? I'm pretty sure that re-fitting the inlet bung and reconnecting the snipped wire should comfortably get the power below 106 bhp, as others have said
Kenif
France
#13 Post by Kenif » Fri Jan 02, 2009 11:11 pm
If ite helps, my first Falco had the Certificate of Conformity as it was originally registered in Gurnsey. The de-restriction mods moved it to where it should be so I guess reinstatement should sort you out...
Katie Did
#14 Post by Aladinsaneuk » Fri Jan 02, 2009 11:53 pm
stock falco in the uk was 104 i think?
finn
#15 Post by finn » Sat Jan 03, 2009 5:43 pm
not much help, but my Falco is a german one.. my registration papers (the german one) says 98 BHP restricted. I also have a german registration paper after the de-restriction 118 BHP. Will have a look in my papers to see if the conform papers are there.
R
Finn
