Grease
Grease
Doing a bit of maintenance and found a white grease on the rear of the brake pads. It was also on the spark plugs which were very easy to remove. I know its not marine grease, but it is really good stuff, anyone know what it maybe ??
Johnr
Johnr
Re: Grease
got to be something similar to copper slip other than that johnl i do'nt knowjohnl wrote:Doing a bit of maintenance and found a white grease on the rear of the brake pads. It was also on the spark plugs which were very easy to remove. I know its not marine grease, but it is really good stuff, anyone know what it maybe ??
Johnr
White? Sounds like Lithium grease. Could be donkey spunk of course, but Lithium grease would be more likely.
- Firestarter
- Twisted Firestarter
- Falcoholic
Sounds like lithium grease commonly known as "white grease"
It's an excellent corrosion inhibitor and resists water penetration comes in aerosols or solid form great on washing machine bearings.
I use it on wheel spindles or as a general assembly grease, it has a high melting point but 1 wouldn't use it on brake pads or pins.
http://shopping.lycos.co.uk/search/white_grease.html
I think this may be it but its expensive stuff
http://www.repaplast.com/products.php?p ... prod_id=64
johnl
johnl
- Firestarter
i've used this ceramic grease on my chain for a couple of years now and find it brilliant, you dont get any over your nice clean wheels or rear end.johnl wrote:I think this may be it but its expensive stuff
johnl
Fastasfcuk - I'm interested in this application. How long does it last? Does it clean off? Does it look a mess on the chain ?i've used this ceramic grease on my chain for a couple of years now and find it brilliant, you dont get any over your nice clean wheels or rear end.
More details pleeease.....
