- Steering head - moved forward 9mm
Fuel tank - moved forward 10mm
Footpegs - moved forward 10mm
Wheelbase - reduced from 654mm (March 08) to 608mm .... meaning the rear wheel has also been moved forward
.... which might be a plan of sheer genius to gain an advantage .... but who's going to break it to them that the front wheel still has to start behind the grid line.
So, now with it in mind that the front of the bike can't actually move forward along the grid, what exactly have they moved?? or even, what is the fixed reference against which all these movements are measured??
They do say:
- Engine Position will be retained
but what does that mean?
Retained relative to the bits that have moved ??
... Well again the whole thing would just be creeping down the grid ....
Maybe the position is just retained relative to this illusive reverence against which virtually the whole bike has moved forward?
... Well maybe that's it ... so if it is, why didn't they just say "we've shortened the wheelbase a bit and moved the engine backwards compared to all the other bits that matter"
