I've been lent a Dell flat screen monitor that my daughter's not using, haven't got any software for it but it's working fine except that I can't find any way of adjusting the brightness or contrast - when I press the usual button on the front it only gives me options for positioning and image settings etc etc, not brightness or contrast - is this normal with a flat screen?
I've been to the Dell site but couldn't find any help or a driver there, well the monitor is about 4 years old, I suppose to them that's obsolete!
BTW it's a Dell E197P
Next question! (Monitor)
- BikerGran
- Gran Turismo
start with the driver
http://support.euro.dell.com/support/do ... eid=160191
then once installed, right click on desktop and select properties and you should be able to adjust things then
- HowardQ
Mine's an E196FP, which is a possibly little bit newer, not sure.
Has yours got the 3 buttons at the bottom RHS.
If so do not press the LH button with the square dispay image on it that goes into the positioning screen, just press the middle one of the three with the " - " sign on it. Use the " + " button to toggle to the contrast and brightness settings.
Select the one you want to change.
Hit the left hand button again, then you can use the + and - buttons to adjust the settings.
Hope this works on yours.
Good luck!
Good luck!
