heated grips ????
heated grips ????
anyone fitted them to a Falco ??
The grip length on the Falco is a bit of an odd length .. shorter than other grips !!
- loafersmate
I have the Oxfords. I had to trim the ends down as they were interfering with the bar end weights. They don't work that well on aluminium bars as they conduct the heat away extremely well, steel bars are better.
- FlyingKiwi
I use the wrap around ones and they work ok I guess.
Good thing is you can take them off when not needed. Soon got used to the extra diameter and they may even be more comfy.
However I am not convinced by heated grips. I get over hot palms in thin gloves and not warm enough in thick ones and either way the backs of my hands feel even colder in the windblast by comparison.
fair point fausto, BUT, even for my winter gloves, I tend to go for those that are thinner around the palms, and thicker over the backs - so i am not affected by wind chill quite so much.
and, sad but true, if I go out wearing thin gloves, and know I am going to be out for a while, I tend to carry waterproofs and spare thick gloves.... guess I am just old and value warmth :)
