Mille front calipers
General Aprilia banter
Kenif
#1 Post by Kenif » Fri Nov 07, 2008 8:34 pm
Does anyone know if the old red calipers can be swapped for the gold Brembos from later models? And if they're the same for Mille or Falco?
Had a bit of an incident with mine and, whilst getting ready to split them and clean out thoroughly, need a contingency plan!
Unless anyone has a set that they want to get shot of? :smt002
Katie Did
Okamoto
#2 Post by Okamoto » Sat Nov 08, 2008 8:23 am
I 've never see the early bike with red calipers ...but if they have showa forks etc I would say yes
The brembo "goldline calipers" were used on loads of italian bikes so should be very easy to get hold of ....pop along to your local bike wreckers and compare some :smt002
Syltiz
Chaos Merchant
#3 Post by Syltiz » Sat Nov 08, 2008 11:54 am
I also believe the answer is 'yes'. Ebay normally has tons of these going as Okamoto says - they were used on many bikes.
Falco9
#4 Post by Falco9 » Sat Nov 08, 2008 12:34 pm
The answer is definately YES
The calipers from most late(ish) Ducatis will also fit, inc the monobloc calipers from the 749 & 999.
The red calipers are excatly the same as the early gold Brembo calipers only the colour changed
F9 :smt006
TreeTops
Re: Mille front calipers
#5 Post by TreeTops » Tue Nov 11, 2008 10:15 pm
Kenif wrote:Unless anyone has a set that they want to get shot of? :smt002
Think I might have a spare set in the garage. I'll have a look tomorrow evening if you like.
Kenif
Calipers
#6 Post by Kenif » Fri Nov 14, 2008 5:28 pm
Hi TT
Thanks for that. Just found out that the calipers are fine and that the master cylinder may have a blocked return valve so probably won't need to replace them
yet
Cheers though :smt001
Katie Did
