Front Brakes pulsing
My front brakes were pulsing and fading badly so have been expecting to shell out on a new set of disks. Thought I would strip the calipers first. 2 out of 6 pistons was very sticky and the pins were completely fouled with road crap. Cleaned all the pistons with toothbrush and brake fluid, cleaned and copper greased the pins, replaced the brake fluid and bled the both sides. Up and down the drive seems completely cured but not had a proper run yet.
Anyone else had this problem? Any recommendations for pads and disks If I one day have to replace them?
Pete
Pete
It is a common problem the Brembo pistons are a bit prone to sticking, worse case scenario is they can damage the disc by pulling it off center. After high mileage with sintered pads the standard disc can get hollow mine did, fortunately RSV and Ducati Brembo disc's are fairly easy to swap from scraped bikes and can be cost effective. I managed to buy a good pair from a Ducati with just 900 miles on them for just £100
Always expect the unexpected
I know that PFM used to market replacement rotors for Brembo discs - not sure if they still do. They were a lot cheaper than replacement discs + carriers, and the rotor material (IMHO) was superior to Brembos. PFM use ductile iron, which is about as good as it gets for rotor material; best used with organic rather than sintered pads, though.
- HowardQ
Pete,
Premier Bikes are now the only "local" Aprilia dealer, but not tried them yet.
They are not too far away at Askern, give them a ring on 01302 703100. They are new Aprilia dealers but should have pads in stock.
Site is -
http://dealerservices.autotrader.co.uk/ ... rbikes.htm
There will be no chance at Halfords near us, only usually have the most common stuff and not many of them!
Failing that, it may have to be mail order via Aprilia Yorkshire or Speedaway.
Site is -
