Falco Airboot
Falco Airboot
Something I did not know (yeah ok, maybe Im just slooow)... the 02+ Falco airboots are resticted:
http://www.af1racing.com/store/Scripts/ ... oduct=2644
Has anyone with an 02+ Falco tried a 00-01 Falco airboot? If so, can you feel a differece? It seems you need the corresponding frame plugs too.
My understanding was the Evo box seals to the bottom of the tank - using it as a new top to the airbox - effectively creating greater volume and retaining the sealed airbox system with the air entering through the standard ducts.
I thought the Renegade one was basically a plate that supports a big filter over the trumpets on the throttle bodies. I believe the plate is not sealed and, therefore, can draw air from all around it. I guess that any that comes through the ducts is likely to be cooler than drawn from over the engine but I'd have thought that the slightly larger orifices in the earlier ducts would have given a very marginal difference (at best) for the Renegade set up .... but that's just my speculation.
Yep, the Rene plate has a big gap all the way round it so sucks in air from all over. As Mr. Rider says, you'd get a bit of cooler air coming in from the intakes when you're on the move, but not a lot of difference in performance from it I'd imagine.
