Rivetting stuff!
Firestarter
Twisted Firestarter
Rivetting stuff!
#1 Post by Firestarter » Tue Sep 09, 2008 12:29 pm
Sorry, couldn't resist :smt003
I bought this chain riveter a while ago, and only used it once when the chain on my Honda Bros snapped. Given my recent chain exploits, I'm thinking of putting a new chain on the Falco (it's got 12000 miles on it anyway, and I haven't treated it that well). Does anyone have any decent experience using these, as opposed to the fancy chain breaker/riveter kits? As I say, I've only used it once, and wasn't 100% convinced by it - using a hammer to knock the pin to flatten off the rivets seems to have disaster potential written all over it, especially given the Falco has a bit more torque than a 650 :smt003
Thanks
#2 Post by D-Rider » Tue Sep 09, 2008 12:54 pm
Sorry - this is not going to help you much
I bought one - a slightly different style to yours - but I guess they work much the same.
I used it to break and re-join the chain when I swapped to the Mille swinger.
TBH, I was not 100% sure that I'd got it joined right - It just seems very hard to tell. Anyway, gave the link a bit of a lever to see if it would all fall apart - it didn't. I've kept an eye on it ever since and it doesn't seem to have moved (other than round the sprockets).
So far, so good.
Syltiz
Chaos Merchant
#3 Post by Syltiz » Tue Sep 09, 2008 1:18 pm
Agree with D-Rider.
The only way to tell is if the "squashed" end of the rivet is roughly the same size as the other pins on the chain. I snapped the handle off my Motrax chain tool but the second one stood up to the job.
#4 Post by Samray » Tue Sep 09, 2008 1:32 pm
It must be several 100% better than just a hammer and punch. :smt053
Firestarter
Twisted Firestarter
#5 Post by Firestarter » Wed Sep 10, 2008 11:52 am
Thanks guys - hopefully get the chain re-aligned tonight, then might nip to Demon Tweeks at the weekend (didn't know they were only in Wrexham!) and pick up a new chain & sprockets (and some sort of chain alignment aid). Then gotta decide whether to fit the 15t front... :smt003
#6 Post by Fausto » Wed Sep 10, 2008 4:09 pm
Firestarter wrote: Then gotta decide whether to fit the 15t front... :smt003
Well that's an easy one :smt003
Firestarter
Twisted Firestarter
#7 Post by Firestarter » Mon Sep 15, 2008 9:21 am
Fitted the new chain - got an Afam one from Demon Tweeks. Removed the old chain with a combination of angle grinder and a screw-driver to lever off the plate, and fitted the new chain with the Whale tool. But wasn't very happy with it - the master link was a hollow rivet (rather than solid rivets with a soft head) - as the Whale tool has a v-groove cut into it, it was sort of flattening the rivet out, but I think it was filling in the hollow part as well, and only putting a lip on the rivet that wasn't going all the way to the plate (kind of a mushroom effect, with the lip of the mushroom not reaching the side plate). Thanks to PaddyZ1 for the second opinion (good timing at riding past his place yesterday :smt003 )
So, got a proper rivet/breaker tool (Motrax, I think), which has a ball-bearing to press into the hollow rivet - worked a treat. Not cheap, but worth it for my own peace of mind. Looking at the pre-made rivets on the chain, they would seem to match the Whale tool groove
So, my suggestion - use the Whale tool for solid rivets, but use something else for the hollow ones (centre punch followed by ball hammer, or a rivet tool)
Firestarter
Twisted Firestarter
#8 Post by Firestarter » Mon Sep 15, 2008 9:23 am
Oh, and the new chain seems to have fixed my "misfire" problem, which on retrospect seems to have been caused by the tight spot continually upsetting the swingarm position. Got a lot worse after I, ahem, "adjusted" the chain but didn't notice that it either slapped the swing-arm, or was drum-tight :smt011
Must remember - check chain before going off half-cocked thinking about spark plugs & leads, filters, throttle body sync etc :smt012
#9 Post by D-Rider » Mon Sep 15, 2008 9:50 am
Well, I'd have never suspected a chain to be the culprit !
Have to check mine over as mine's backfiring too (not as bad as it was before I changed the PCIII map to a Tuono one though)
#10 Post by Samray » Mon Sep 15, 2008 10:26 am
Discovered a tight spot when the cibber was on a dyno once. Gave some most peculiar readings.
#11 Post by Fausto » Mon Sep 15, 2008 2:59 pm
Firestarter wrote:Oh, and the new chain seems to have fixed my "misfire" problem, which on retrospect seems to have been caused by the tight spot continually upsetting the swingarm position. Got a lot worse after I, ahem, "adjusted" the chain but didn't notice that it either slapped the swing-arm, or was drum-tight :smt011
I'm sorry but can someone explain..... Tight spots = misfire :smt017
#12 Post by D-Rider » Mon Sep 15, 2008 3:25 pm
I think it's the biking equivalent of alternative medicine
Firestarter
Twisted Firestarter
#13 Post by Firestarter » Mon Sep 15, 2008 3:49 pm
The chain was so tight (and I hadn't noticed it :smt009 ), it was actually causing the bike to lurch as it rotated, causing me to think it was misfiring - started off mild, but got a lot worse when I mis-adjusted the chain
#14 Post by Falcopops » Mon Sep 15, 2008 9:41 pm
Firestarter wrote:The chain was so tight (and I hadn't noticed it :smt009 ), it was actually causing the bike to lurch as it rotated, causing me to think it was misfiring - started off mild, but got a lot worse when I mis-adjusted the chain
:smt045 Had exactly that coming all the way back from Monza. Imagining all sorts of expensive problems, turned out to be a knackered chain with a big tight spot.
