instrument cluster
mrapriliafalco
instrument cluster
#1 Post by mrapriliafalco » Fri Aug 01, 2008 8:10 am
wonder if someone can help me.
the lights are not working on the instrument cluster, the speed o, rev counter and everything else does not lite up.
any suggestions? Also one side of the rear lights and the brake lights are not working, could that be connected or is it just a bulb?
#2 Post by D-Rider » Fri Aug 01, 2008 9:02 am
For the rear light, check that the connector is pushed in properly on the side that's not working.
Have you checked fuses for the other stuff - or the connector ?
mrapriliafalco
#3 Post by mrapriliafalco » Fri Aug 01, 2008 9:09 am
Thanks for reply mate the rear was just a bulb, but as for the instrument cluster its in the same fuse circuit as the horn indicators etc etc which work fine.
Dont want to start probing around the back unless I know what I am looking for as I always break more :smt017
sabestian
#4 Post by sabestian » Fri Aug 01, 2008 11:34 am
There is a huge plug at the back of the dashboard, mine become loose the other day. Check that.
