I'll need one of the set, the other one is yours for 30 delivered (which incidentally happens to be exactly 50%).
I was lucky enough for them to miss the customs, so the nerve wracking part of the job is done.
H7 (fits Falco, donno about the rest).
6000K, which is a good compromise between seeing and being seen.
Slim ballast (see photos - yes, it is THAT slim!) should be far less problematic to fit than standard (that's why I went for these).
No instructions included but if you use the search button there is plenty out there (RiderSite and AF1).
PM me if you want it!
Edit: this is 35W unit.
Disclaimer: I have not fitted mine yet, so no advise from me but there is more then enough out there.
