Question for the electrically minded amongst you.
#1 Post by Falcopops » Thu Jun 12, 2008 1:32 am
I had HID headlight unit fitted that worked fine even with a mod to the hi-beam switch, that kept the headlight on when the main beams were switched on.
The only problem was if I stalled and restarted or restarted without turning the headlight off the draw on the power put the HID out. Not too much of a problem, but I’m a committed fettler and this just wasn’t good enough.
My solution was to wire a normally closed relay in using a tap off starter relay feed from the starter button to the new relay solenoid and a wire to ground to fire relay and cut power to the HID ballast on startup. This works fine and the HID turns off when the starter button is pressed and reignites when it’s let go.
However, when I switch on the hi beams the HID goes out now, but it didn’t before.
The mod to the hi beam switch shouldn’t be the problem as it worked before and is merely a wire relocation and still uses the separate relays for the head and hi beam lights.
T’was late last night when I was testing this and only just remembered I’ve replaced the hi beam bulbs with more powerful items, but doubt that’s the problem and easily checked.
I’m thinking that instead of running the new relay solenoid current to ground (therefore in parallel with the starter relay) I should have put it in series with it, again I can easily try that.
Any ideas greatly appreciated.
Where's Spock when you really need him?
Re: Question for the electrically minded amongst you.
#2 Post by Gio » Thu Jun 12, 2008 1:54 pm
Falcopops wrote:Where's Spock when you really need him?
He's on that other web site isn't he (forgot their addy)
#3 Post by Samray » Thu Jun 12, 2008 2:54 pm
Gio wrote: (forgot their addy)
#4 Post by D-Rider » Thu Jun 12, 2008 8:10 pm
You need Scotty - this is a job for an Engineer!
#5 Post by Kwackerz » Thu Jun 12, 2008 9:07 pm
It's in the links..
#6 Post by D-Rider » Fri Jun 13, 2008 2:36 pm
BTW Dale, I will try to have a look at this but need to dig out the wiring diagram to try to figure out what's going on .... I'll get back to you.
#7 Post by Falcopops » Sat Jun 14, 2008 7:09 am
Thanks Andy.
I'll try to lash up a circuit diag of what I've done whenI'm at work on Moday
#8 Post by Falcopops » Mon Jun 16, 2008 4:10 am
Her's a diagram of what I've done (doesn't include the Hi-beam mod, but you know how that works) Red for positive blue for negative
