coolant Q
k1w1boy
coolant Q
#1 Post by k1w1boy » Thu May 08, 2008 9:14 pm
...seem to be going through it at the mo' with no sign of leakage. A bit paranoid after crash - how often do folks typically top it up summer riding/ commuting?
Falco9
Re: coolant Q
#2 Post by Falco9 » Thu May 08, 2008 9:39 pm
k1w1boy wrote:...seem to be going through it at the mo' with no sign of leakage. A bit paranoid after crash - how often do folks typically top it up summer riding/ commuting?
In a word "never" either on the Falco or now on the T. If you're using it, it's leaking from somewhere. Maybe worth getting your friendly dealer to do a pressure test if you can't see any obvious leak.
F9 :smt006
#3 Post by D-Rider » Thu May 08, 2008 9:39 pm
um ....... never ......
:smt048
#4 Post by Falcopops » Fri May 09, 2008 2:39 am
isn't there an odd ocurrence of some T piece leaking somewhere between the pots?
tyr a search
k1w1boy
#5 Post by k1w1boy » Fri May 09, 2008 9:56 pm
...thanks y'all. Will search the forum and keep investigating. FYI - anyone folowing my repairs, the rear brake caliper hanging bracket that was wrecked in my tumble ended up taking my spanner monkeys about an hour to remove and replace after I got a cheap part on ebay - stupidly expensive given how little impact not having a rear brake for a month had on my riding :smt011
