clic clamp Vs jubilee clip
Big_AL
#1 Post by Big_AL » Wed Apr 16, 2008 9:44 pm
Thinking about doing an oil change at some point, and want to do it properly and clean out the engine oil filter which means i'll have to remove the clic clamp that holds on the hose. Question: do i get special tool and replace clic clamp with another clic clamp or can I just use a regular jubilee clip / worm drive jobbie instead? What do you guys do?
#2 Post by D-Rider » Wed Apr 16, 2008 9:52 pm
Think I read somewhere that Aprilia tell you that you must use click clamps .... but that wouldn't stop me from using a Jubilee clip as I've not got any of the others or the right tool
#3 Post by Falcopops » Wed Apr 16, 2008 11:13 pm
D-Rider wrote:Think I read somewhere that Aprilia tell you that you must use click clamps
Aprilia is ambiguous on this. There is certainly aomething written in their manuals that says you must use the proper "click Clamps", but in another Aprilia manual I says you can use jubilee type clamps.
Anyhoo, I and many others have used jubilee clips, with no ill effects.
When mine was serviced a while back the stealer reused the o/e clips and they were in a shocking state (still working, but not confidence inspiring). Use jubilee ones and that problem goes.
sabestian
#4 Post by sabestian » Thu Apr 17, 2008 11:17 am
When I changed the radiator I was just really careful with removal of the original clip and I managed to fit it right back (looks and feels good as new). I've noticed during long years of research :) that jubilee clips (especially lower quality ones) have a tendency to unwind sometimes (possibly temperature changes (?)) or to break and slip so perhaps using locktite would be a good idea?
#5 Post by Fausto » Thu Apr 17, 2008 5:09 pm
Waxed string and a reef knot should do it
Big_AL
#6 Post by Big_AL » Thu Apr 17, 2008 8:28 pm
cheers peeps, you confirmed my suspicions :smt001
Falco9
#7 Post by Falco9 » Fri Apr 18, 2008 7:41 am
FYI.
The AF1 Tuono site is currently littered with reports of coolant & oil leaks from the 06-08 Tuono's due to the poor sealing of the "click" clamps Aprilia are currently using.
To be fair I never had a problem with any of the clips on the Falco (replaced the lower clip when I did the oil strainer filter) and none have leaked so far on the T
But a number of the Americans are now using these clips (below) and a lot of Tuono owners are relacing the click clamps with good old Jubilee's just to be on the safe side.
http://www.eagleday.com/normaclamps.html
Don't know if you can get these here in the UK though
F9 :smt006
#8 Post by D-Rider » Fri Apr 18, 2008 12:33 pm
Like the look of those F9 .... seem to be the best of both worlds.
Falco9
#9 Post by Falco9 » Fri Apr 18, 2008 12:41 pm
Found em!
http://www.norma.co.uk/docs/tabstrip.as ... 2&m6=31426
and Norma's UK contact details are:-
Norma Products Limited
Weber Road, New Greenham Park
GB - Newbury, Berkshire RG19 6HW Telephone: +44 1635 521880
Fax: +44 1635 574031
E-Mail: sales@norma.co.uk
Would you believe I drive right past this business park on my way to the office dozens of times a year! Small world eh?
F9 :smt006
#10 Post by Nooj » Fri Apr 18, 2008 4:53 pm
What ever you decide, get stainless ones so it doesn't look like someones smeared your bike in orange shit in a couple of years.
Big_AL
#11 Post by Big_AL » Sat Apr 19, 2008 6:06 pm
my local car shop sells those norma clamps (or at least look similar) I'll probably use those when i finally get round to changing the oil, sadly i've got myself lumbered with a load of diy at the mo, bathroom, cloak room and a nursery. No rest for the wicked :smt012
