I left the grips on for a test as the Oxford instructions state they will switch off if they detect battery voltage dropping (they are connected direct to the battery). Needless to say, they drained the battery to below the level needed to crank the starter, so she is now on the optimate!
It is inevitable that at some point I will forget to switch the grips off after use, so would prefer to wire them in to a switched live so they are turned off when the ignition is switched off.
Has anyone done this and can tell me which wire I can splice into coming off the ignition?
Many thanks!!
