John1000
#1
by John1000 » Thu Jan 18, 2007 10:12 pm
Got my self a double layer DVD burner but found out the discs are dearer that the burner what’s all that about?
Can I use normal ones and do dvd players play these things anyway?
#2
by Kwackerz » Thu Jan 18, 2007 10:17 pm
Yes you can use conventional DVD discs. It just means you only have 4.7 gb to play with on each disc. with dual layer, you get double that. (but obviously need the dual layer discs in order to achieve that)
John1000
#3
by John1000 » Thu Jan 18, 2007 10:30 pm
Thanks Kwackers its just that I cant seem to get normal dvds to burn.
Will have to take a bit of time to sort it out I guess thank for getting back.
#4
by Kwackerz » Thu Jan 18, 2007 10:33 pm
Is it a + and - R burner? or just a -R or just a +R? The DVD formats are different and one wont work on the other, however both will (obviously) work on a + /- R burner.
My desktop pooters will do both, however my laptop will only do -R's
