A little bit faster, a little bit lighter, a little bit more compact than before… So goes the well-tried formula that's marked the progress of sports bikes since the first Fireblade turned the niche upside down in 1992.
Back then, the world's fastest bikes had been getting bigger, heavier and more powerful in their quest for rival-crushing speed, a trend Honda's senior designer, Tadao Baba, bucked dramatically by gaining performance through losing weight. Hence the original Fireblade produced less power than its rivals from its smaller 893cc engine at 122bhp, but with its ruthlessly pared 408lb dry weight, it simultaneously consigned the rivals to a pillion passenger's worth of surplus metal. It was faster in a straight line, would vanish given some corners and it put the "sport" back into sports bike.
It took Yamaha another six years to see the light(ness), Suzuki even longer and Kawasaki well into the next century, but now all are following Honda's path with the zeal of religious devotees and sports bikes are the better for it. No room then for further revolutionary conversions, but Honda, it seems, has done it again with the 2008 Fireblade, albeit in a more restrained fashion.
It's not the engineering philosophy that has been upended this time around, but the styling ethos: just as Honda realised in the 1990s that it had been giving lorries to people who wanted sports bikes, so now it understands that superbikes have been styled like shellsuits for people who shop in Savile Row. Okay, exaggerating a little there, but, typically, a superbike buyer is a man in his forties or fifties, with money to spare, more Aston Martin than Impreza Turbo, and not really a fan of bright colours or lots of stripes. So the new Fireblade has an air of class with some upmarket, conservative paint schemes, such as the velvet red and black of our test bikes, and there are details like the inset cloisonné tank badges in place of the usual stickers. It's so different that it feels like a bold, perhaps risky move, even though the bike, in marketing theory at least, is now styled to match the people buying it. One potential hurdle is that those buyers might fit one marketing segment but like people to think they belong to another - the superbike as a mid-life crisis panic purchase should perhaps look like a young lad's machine.
Secondly, it has to look impressive and go well, and here the '08 Blade does just fine. In early pictures the snub-nosed front looked vaguely like some sea-dwelling mammal, but in the aluminium flesh it's simply lean and purposeful. It's also remarkably small, worrying for this rider at 6ft 3in, but once on board you discover the bar-peg-seat relationship is much the same as the previous Fireblade, which is just as well as riders are growing rather than shrinking. More of a surprise is the raw feel of the motor when you fire it up. The super-compact four-cylinder engine vibrates through the machine and almost does a double-take pick-up in response to the throttle, like a race engine and very unlike a Honda. This is real progress for a company so often criticised for the bland perfection of its bikes, as it gives the Blade real character.
Release the light-action clutch and the bike surges forward. A loss of some low-rev torque compared with the old model is countered by slightly lower gearing and the impressive loss of 12lb. Thanks to more of the mass being concentrated around the centre, the Fireblade turns with more eagerness and changes direction more willingly. This was especially noticeable at Qatar's Losail circuit, where our ride took place. Through the track's high-speed left-right flicks, the '08 machine responded faster to less handlebar effort.
The chassis is a delight, the speed-variable electronic steering damper taming corner-exit waywardness without affecting agility, while feedback and manageability are as good as any road rider could want. On standard suspension settings the bike makes a good fist of high-speed track riding and, with suitable adjustments, it's a sharp circuit weapon that's enormously satisfying as well as very forgiving. This could well be 2008's best superbike for the road, although the Suzuki GSX-R1000's low-rev torque might still give that the edge. But Honda has finally acknowledged that road bike riders do go places on their bikes, and offers a tank bag and tail pack for carrying a change of clothes and some wet weather gear for the odd weekend away.
The engine is as ferociously powerful as you'd expect, its 175bhp hurling you forward like a jet fighter catapulting off the deck of the Ark Royal. Having said that, it's a touch shy of its rivals in outright power and doesn't have quite the same final top end hit of horsepower - as if you'd notice in the real world, or really want for more.
The soundtrack is as interesting and evocative as the new-found feel to the motor, but it's still as easy to modulate and obedient as Honda's sports bikes have always been. The clutch is assisted by ramps that work in its favour as the drive is transmitted, which sometimes results in odd pulses through the lever as you change down, but you get used to that. Less welcome are the heavy upchanges in full-bore acceleration: you have to exaggerate the throttle-off action to really unload the transmission or the gearlever can balk at selecting the next ratio, at least compared to the standard-setting GSX-R with its crisp and featherlight shifting.
But, dynamically, those are the only criticisms you'll get from me and visually the Fireblade is playing a pioneering role once again. It's looking very good indeed.
It sounds like the Blade has come back to it's ripsnorting earth shattering roots after some of the later incarnations which appeared to see the beast tamed somewhat by Honda... If you can call it 'tamed' ...
Source of Article: Telegraph.co.uk
