Which DOT?
FalcoJock
Which DOT?
#1 Post by FalcoJock » Wed Feb 27, 2008 12:44 pm
I recently refreshed the clutch fluid, but could only get DOT 4 at the dealers I tried close to home (I wanted to get it done quickly). They are an Italian bike specialist, including Aprilia, and had done a full sevice on mine a year ago. They said they only use DOT 4 and that's what they would have put in mine at the service. It has been OK for the last year. However, Aprilia recommend DOT 5 or DOT 5.1 (DOT 4 compatible).
It seems to me that the DOT number is about operating temperature ranges and DOT 4 is fairly high. Any opinion as to whether DOT 4 is OK in the clutch?
I did go for a long run afterwards and it all seems OK, but I'm never sure about trusting dealers.
#2 Post by HowardQ » Wed Feb 27, 2008 12:57 pm
I've used DOT 4 in mine and it has always seemed OK.
#3 Post by Aladinsaneuk » Wed Feb 27, 2008 1:14 pm
iirc correctly dot 4 is the boy - and dot 5.1?? but not dot 5 for some reason?
#4 Post by HowardQ » Wed Feb 27, 2008 1:20 pm
I stand corrected Pete, whenever I have used Dot 4 it has been fresh new stuff, not sure what the difference is between the two, probably a revised standard with only minor differences.
Tweaker
Main bike: BMW R1250RS
#5 Post by Tweaker » Wed Feb 27, 2008 2:55 pm
DoT's 3,4 & 5.1 are all glycol based fluids. DoT 5 is silicone based. The DoT number refers to the fluids boiling point, both when new and after water absorbsion, and the higher the number the higher the boiling point. What you can't ever do is mix 5 with any of the others - it turns to emulsion, even with tiny amounts of contaminant.
The other thing to consider is that some seals and brake components may not react well to silicone fluid if they weren't designed for it. If the handbook says DoT 5 is OK then your fine, if not stick with the glycol based fluids. Also, apparently, DoT5 fluid, whilst resisting moisture absorbtion, is very prone to aeration so needs changing more regularly and can lead to a softer feel to the brakes - so 'They' say!
Think I'll go change me anorak now...... :smt112
FalcoJock
#6 Post by FalcoJock » Wed Feb 27, 2008 4:43 pm
Thanks all, especially Teaker's very full answer. I found the remnants from my previous fluid change a few years ago and it was 5.1. So at some stage it's gone from 5.1 to 4. But it's been fine and your answers have convinced me I did the right thing.
FalcoJock
#7 Post by FalcoJock » Wed Feb 27, 2008 4:45 pm
Tweaker even!
scorpio24v
#8 Post by scorpio24v » Wed Feb 27, 2008 7:17 pm
DOT 4 is the stuff to use.
#9 Post by D-Rider » Wed Feb 27, 2008 9:46 pm
Tweaker wrote:If the handbook says DoT 5 is OK then your fine, if not stick with the glycol based fluids.
The handbook is badly phrased.
It says DOT 4 or DOT 5 (DOT 4 compatible) ... or words to that effect.
As you point out DOT 5 is certainly not DOT 4 compatible.
I think what they are trying to say is you can use a fluid that fits within DOT 5 numbering but is compatible with DOT 4 .... in other words DOT 5.1
Dangerously confusing cos if you put DOT 5 in you contaminate the system
Tweaker
#10 Post by Tweaker » Thu Feb 28, 2008 11:36 am
D-Rider wrote:The handbook is badly phrased.
Could have been worse Andy - could have been translated from Japanese instead of Italian! :smt017
#11 Post by D-Rider » Thu Feb 28, 2008 12:04 pm
You're so right there Dave !
Spend half my life trying to figure out what people mean from the nonsensical words they've written.
(guess the rest of the world has to do that with the stuff I write!)
#12 Post by HowardQ » Thu Feb 28, 2008 12:30 pm
In your case Andy there is no problem in understanding it, it just takes time to read it :smt003
It's usually well worth the effort though.
