Skidmarx bellypan...mounting points?
exupmonkey
#1 Post by exupmonkey » Tue Feb 26, 2008 8:28 pm
Chaps...got hold of a Skidmarx bellypan (thanks Nigel) but I am at a loss as to how to mount the rear of it to the bike. There are two pre-drilled holes either side to the rear which don't seem to marry up to anything obvious...or am I missing the obvious (quite possible :smt003 ). Does it require some extra fettling or a bracket of some description, anyone shed some light?
falcomunky
#2 Post by falcomunky » Tue Feb 26, 2008 8:50 pm
Ya gotta make a couple of brackets fella! :smt003
You should be able to offer the pan up to the bike n figure out the best bolts to use and what type of bracket you need. One of em, (gear lever side I think), needs to be S-shaped...
If I could be arsed Id go out n look at mine but its blowing a gale out!... :smt006
Two is the magic number... ;)
FlyingKiwi
#3 Post by FlyingKiwi » Tue Feb 26, 2008 9:22 pm
I'll have a look in the morning if no one gives u an answer before
#4 Post by Aladinsaneuk » Tue Feb 26, 2008 9:30 pm
should have come with two s shaped brackets....
if i strip my falco down over the next couple of weeks I can maybe send to you as a template?
(I am contemplating something so may have it in bits....)
exupmonkey
#5 Post by exupmonkey » Tue Feb 26, 2008 10:36 pm
News just in fellas....checked the bottom of the box and low and behold I found the brackets....Confirmation achieved, Exupmonkey is a twat :smt003 . Thanks all for your replies
Getting my coat now!
#6 Post by HowardQ » Tue Feb 26, 2008 11:22 pm
Only problem you now have is lining them up, as you can't see much when the belly pan is in place. Start with the brackets a bit loose on the engine so you can still move them a bit, then line up the belly pan and move the arms slightly until it looks OK. Take belly pan off and fully tighten the mounts onto the gearbox and put it back again.
I now locktight all four bolts, each time I replace the unit, as I once lost the bolt that goes through the fairing to the bracket. Needed because you can't tighten this one up too much without damaging the fibre glass.
Almost forgot, I also use rubber tap washers between the panel and the bracket to stop any risk of cracking the belly pan.
Good luck with it mate, IMO the bike looks 100% better with the belly pan fitted.
exupmonkey
#7 Post by exupmonkey » Wed Feb 27, 2008 12:18 pm
I now know what you mean Howard, a bit of a pain to fit but I seem to have managed it without breaking anything which is somewhat of a novelty for me :smt001 Rubber washers installed and looks great, well worth the 'effort'.
Goldie
#8 Post by Goldie » Wed Feb 27, 2008 1:23 pm
I should have read this before I replied to your PM Andy. :smt005 :smt005 :smt005 :smt005
Another Fine Product From The Nonsense Factory
exupmonkey
#9 Post by exupmonkey » Wed Feb 27, 2008 4:00 pm
Likewise....I should have checked the box before posting :smt108 :smt003
