just to add on to the work I have done this winter and to give some initial thoughts on the effect
First off, nounting the garmin on the dash - not good - the dash is far to flexible so the garmin bounces around far too much - I will be getting a metal working friend to look at this with me and we will make a support bracket to stop it... if that does not work then I will think again - I really like the placement....
Second - MPL clutch master cylinder. Awesome - easy clutch action, and wish I had done it earlier
Third, AF1 chip... oh my :) you get to 7k revs then it takes off - hard :)
Fourth - Wavey disks and braided hoses. Hard to quantify and to sperate. I am not certain what the difference has been caused by BUT - the brakes are better, and have far more feel in them. I suspect this could be down to better bleeding as I followed the guides, but could be down to new fluid or braided hoses - either way, lovely :)
Fifth - integrated indicators. I like the look - the clean lines are nice - BUT - maybe the rear indicators are not enough as they are for safety - I will be looking again at these and thinking about a solution
Sixth - Baglux tank cover in black... even though I do have a baglux tank bag in blue - I do not like this - I will be removing the cover and keeping the tank standard - and yes, I will be selling on the cover and bag!
Finally - the HID conversion - trust me folks, just do it - awesome effect and, in all honesty, I will not be doing the high/low beam light mod - I do not need too - the dip is enough on its own...
so - mixed results, but am pleased - I have a little more fettling to do, and have a couple of ideas to try for the future :)
Mods review = part one
- HowardQ
I've also got a black Baglux tank cover, (my tank bag is also a different colour, red off an earlier Honda I had!).
I used to fit the tank cover on each winter when there was a lot of gravel flying around, so it protected the tank.
I am not happy with the tank cover on all the time, so I just fit it when I need the tankbag.
Why not do the same Pete, just use it when you need it.
The bike does look better without it on, but there ain't a better way to fit a tank bag on a Falco on those days you need to take luggage.
possibly agree about the baglux bag - but I do have the genuine aprilia luggage set....
and no problems with finding neutral at all - but, tbh, I do tewnd to select it as i approach a traffic light on red etc, not when I have stopped... but, no problem that i have noticed either way :)
- HowardQ
Funny thing this finding neutral, mine has never changed over the 3 1/2 years plus that I've owned it.Aladinsaneuk wrote:.... and no problems with finding neutral at all - but, tbh, I do tewnd to select it as i approach a traffic light on red etc, not when I have stopped... but, no problem that i have noticed either way :)
Very difficult (almost impossible) getting neutral from 1st gear.
Much easier (almost 100%) getting neutral coming down the box from 2nd.
These comments are when bike is stood, and I am still using the standard clutch cylinder, (with the special black Aprilia hydraulic fluid
Just means I've got into the habit of moving 1st - 2nd - neutral when I stop.
If I select neutral as I come up to traffic lights, it is almost always coming down from 2nd gear, so no problem at all.
