non starter!!
Torn
non starter!!
#1 Post by Torn » Tue Jan 16, 2007 10:34 am
Hi all
had problem with my falco yesterdya it wouldnt start, it fired on first attempt but didnt start then after that it wouldnt start at all, tried to get it going a few times but now all im getting is a clocking noise from one of the relays under the rear seat and nothing else when pushing the starter button, i have ordered a new relay to try and see if that fixes it, if not im gonna have to push it a mile from home and call out the recovery people to take it to southern cross, any one else experienced this ? and does it sound like the relay is knackered? im not a very mechanically minded person. optimate is telling me my battery is fully charged, this has happened once before but when i got home after getting the train to work it started first time but yesterday evening still all i was getting was a clicking from a relay.
any help appreciated
thanks dave
#2 Post by Falcopops » Tue Jan 16, 2007 11:08 am
Solenoid probably matey.
If the relay is clicking it's working.
I reckon the noise you are hearing is the starter solenoid trying to connect, but failing. It's been covered a few times, I think the latest victim was on the AF1 site.
The solenoid is on the right side under the plastics. Take the plastic off and short across the solenoid terminals with the ignition on, don't use your best tools for this as they will probably melt a bit. If it starts then it's the solenoid. I think there is a yahaha or honda part that is cheaper and more readily available.
Good luck.
#3 Post by Falcopops » Tue Jan 16, 2007 11:10 am
And another thing!
I thought you were due for a service. If it's still in warranty I would push for a replacement for free.
Torn
#4 Post by Torn » Tue Jan 16, 2007 11:24 am
thanks pierre, pops it is due a service its booked in at dons on 6th feb :smt014
ill have a look for some parts
thanks d rider
#5 Post by D-Rider » Tue Jan 16, 2007 11:55 am
Yep - if it's under warranty get them to sort it out for you.
If not, as 'Poops says, this has been covered before on the AF1 site - together with part numbers of alternative components that are better specified and cheaper.
Here are some links:
http://www.apriliaforum.com/forums/show ... r+solenoid
Torn
#6 Post by Torn » Tue Jan 16, 2007 12:27 pm
ive just ordered the yamaha part for £32 delivered should get it tomorrow, fingures crossed it works :smt017
Falcoholic
#7 Post by Falcoholic » Tue Jan 16, 2007 1:07 pm
IIRC then the solenoid connections can work themselves loose. I know mine did and melted the cover.
Also make sure your battery has a full charge. The bike needs a fair bit of power to throw the solenoid.
Good luck
The Delicate Sound of Thunder
Torn
#8 Post by Torn » Wed Jan 17, 2007 8:06 pm
fitted the yamaha solenoid tonight and it fired first time, one of the covers on the old one had been slightly melted, yam one is a perfect fit and it seems to fire up quicker than before :smt003
thanks for the advice/info much appreciated
dave
