TheToolbox
TheToolbox
#1 Post by Samray » Tue Jan 15, 2008 3:49 pm
Hammer - In ancient times a hammer was used to inflict pain on ones enemies. Modern hammers are used to inflict pain on oneself.
Screwdriver - The drink ordered at the local bar after you call in a professional repairman to undo the $500 in damage you did while trying to change out a light socket with your handy screwdriver.
Phillips Screwdriver - The bar drink that you order when the damage estimate is over $1,000. Contains twice the vodka.
Pliers - A device used to extend your reach the necessary few inches when you drop a one-of-a-kind screw down behind the new wall it took you two weeks to install.
Multi-Pliers - Contains a handy assortment of sharp and dangerous tools. Best left in its leather sheath and worn on a homeowners belt to increase testosterone levels.
Electronic Stud Finder - An annoying device that never goes off when you point it at yourself.
Halogen Light - A worklight that lights up your backyard with the incandescence of a football stadium, causing you to cast a heavy shadow over the area you're working on so that you need to use a flashlight anyway.
Cordless Drill - A device that lessens your chance of electrocution 90% over a standard plug-in tool.
Cordless Telephone - The handyman's 911.
Air Compressor - A mechanical device similar in principal to harnessing the power of your mother-in-laws nagging complaints and using the resulting airflow to blast old paint off the side of the house.
Chainsaw - Allows you to cut your way out of the shed that you accidentally built completely around yourself.
Vise Grips - A pair of helping hands that doesn't critique the job you're doing or offer advice.
