Get My Falco Tomorrow !
sidestand
#1 Post by sidestand » Fri Dec 21, 2007 6:19 pm
Everythings finally sorted, so I I pick me Falco up at 12.30 pm tomorrow
(I have even told the wife I'm getting it - her Christmas prezzie to me ) :smt003
Alarm/immobiliser in the new year though, so I'll have to rough it on the Fazer Thou/TDM/K1200S until then :smt009
#2 Post by Fausto » Sat Dec 22, 2007 4:19 pm
That will feel like a very long time...... but it will be worth the wait :smt003
Once you have some miles under your belt I would be interested in a comparison between the Falco and the TDM. Is it a 900 ? Obviously different ergonomics but aren't the TDM engines supposed to have been tuned to ape the characteristics of a V twin? It is a bike I would consider if it feels similar to a Vee ( and my Falco died :smt009 )
sidestand
#3 Post by sidestand » Sat Dec 22, 2007 8:32 pm
The Falco is now in my garage with the others :smt003
Spent some of today giving it a good clean & check over
It needs a new back tyre fairly soon, & the chain is a bit rusty (got a spare scottoiler somewhere, so that can go on in the New year)
Otherwise it looks fine. That red rev limit line goes on a bit early, but thet can be adjusted can't it ?
Weather is a bit crap to give it a good try out, especially with a cold, square rear tyre.
You're right about the TDM's Fausto, mine's a MkII 850, which is the one where they altered the firing from 360 to 270 deg to simulate a big V twin. The 900 is the improved version, with fuel injection & a much improved six speed gearbox.
All TDM's are brilliant to ride & are a very under-estimated bike. The ride & performance are very similar to a BMW R1200GS
but for half the price. Top speed is about 135mph & a lot of riders claim 50mpg, although I reckon 45 is nearer the mark.
Great for all day long two up touring, & I regularly take my young 'un on weekend camping trips on my 850
I'll look a photo out of it if you like
#4 Post by D-Rider » Sat Dec 22, 2007 9:11 pm
sidestand wrote:That red rev limit line goes on a bit early, but thet can be adjusted can't it ?
Yes - absolutely - If you get a reset of the clocks it'll reset to 6k - it can be set from that point upwards.
The manual states for a run-in engine, the max revs should be 10.5k - many of us set our warnings just a bit below - say 10k or 10.25k (ish)
A handy set-up guide for the clocks is HERE
It's all in the user manual as well - if you haven't got one, you can download that from the same site or directly from Aprilia HERE
You can also download a workshop manual from Martin Poll's site (the first of these links) .... but it is a BIG download.
Enjoy your new toy :smt003
#5 Post by Gio » Sun Dec 23, 2007 9:25 pm
My sons Falco is set at 11k and I'm sure I read somewhere that others have it up at 12k :smt018
#6 Post by D-Rider » Sun Dec 23, 2007 11:56 pm
I've checked the book. It is possible to set the warning light at a value between 2000 and 12000 rpm however the maximum recommended rev limits are:
0-625 miles: 6000 rpm
625- 937 miles: 7500 rpm
over 937 miles: 10500 rpm
See p49 of the user manual
I see little point in revving any higher - you'll get more grunt from the next gear in the box.
I'd knock your son's warning light down a bit - no sense in over revving the thing.
#7 Post by HowardQ » Mon Dec 24, 2007 12:56 am
Must agree with Andy, it's only the warning light you adjust anyway, the limiter comes in around 11K (??) I believe, so not much point having the warning light set at 12K. Mines also at 10,500, it just gives you a bit of warning before you hit the limiter very soon after.
FlyingKiwi
#8 Post by FlyingKiwi » Mon Dec 24, 2007 8:04 am
I never rev mine that high.
My indicator was set for 7000 and peak torque :smt001
#9 Post by Gio » Mon Dec 24, 2007 8:17 am
D-Rider wrote:I've checked the book. It is possible to set the warning light at a value between 2000 and 12000 rpm however the maximum recommended rev limits are:
I presume this means disconnect the battery and reprogramme?
FlyingKiwi
#10 Post by FlyingKiwi » Mon Dec 24, 2007 9:40 am
From memory you press button "C" then press and hold again to increase the needle in 200rpm increments
#11 Post by D-Rider » Mon Dec 24, 2007 11:43 am
Gio - go to the links I posted earlier in this thread - they tell you how to adjust it .....
#12 Post by Fausto » Mon Dec 24, 2007 5:31 pm
HowardQ wrote:Must agree with Andy, it's only the warning light you adjust anyway, the limiter comes in around 11K (??) I believe, so not much point having the warning light set at 12K. Mines also at 10,500, it just gives you a bit of warning before you hit the limiter very soon after.
Who in all the world is looking at their clocks when hitting the rev limiter ???
I don't remember where my light is set but it does occasionally flash under acceleration which I find distracting. So I guess I should set mine to 12K :smt003
wonderdog
#13 Post by wonderdog » Tue Apr 22, 2008 11:13 pm
I leave my red light at 6k,this equates to 100mph in 6th,so I then have a quiet marker letting me know when I am in real 'lose yer licence" territory.
minime
#14 Post by minime » Wed Apr 23, 2008 7:14 am
I have set mine to STOP flashing above 5000 RPM. This reminds me not to under-rev the damn bike... :smt003
#15 Post by D-Rider » Wed Apr 23, 2008 7:50 am
wonderdog wrote:I leave my red light at 6k,this equates to 100mph in 6th,so I then have a quiet marker letting me know when I am in real 'lose yer licence" territory.
Seems a good idea .... but doesn't it drive you mad flashing away getting up there ?
.... and is it actually easier to spot than those big digits that say 100 (or whatever)? - maybe it is because it flashes.
Oh - and welcome by the way
BTW, I set mine at about 10,250 rpm
