Welding
Welding
I'm trying to get my forge welded together to no avail. Either people say they can't do the steel part or they tell me to come back......the one place that has said they will do want £200 to weld it together. I'm being particularly Scottish about this because I've always wanted to learn to weld so sort of figure this is a good time to do it.
Any suggestions? I've tried the local college, their course starts in Septemeber each year but I want to use the forge before then.
Been reading up a bit and think a MIG is the way to go but I'm pants at electrics.........what wattage/ampage/voltage etc should i go for? And any other helpful suggestions. In the meantime I'm off looking for another training establishment.
An 180 amp MIG should be more than enough for most home jobs, welding up to 5mm thick steel and can be run off domestic 13a supply ..unless it's used on high settings for long periods! then a dedicated 16a supply should be installed, plus they are set up for a large size co2 / argoshield bottle instead of the crap small things.
But with all things you get what you pay for so buy the best your money will get...have a word with your local welding supplies shop I'm sure they will have some good advice and maybe do a good deal on a small machine ...many shops will let you try them out in house before you buy.
Why not fix your forge with straps of 5x25mm steel bar drilled and bolted ..a classic blacksmiths bodge ha ha.
Gio, Forge. Based on an american design, it is a proper blacksmithing forge [albeit in bits] with a blower to change the intensity of the fire. It will use coke to produce the fire and rather than firebricks around the outside you can use compacted coom [sp?] used for making tools and varying other items from scratch from plain bars of metal. I'm not sure what you mean by a modern equivalent unless you mean a gas forge?
Thanks Okamoto, from what you've said it sounds like a stick welder is going to be the way to go, I can go down to thinnish metals but for the heftier furniture work I will still be able to fix things safely.
