oil pressure switch
oil pressure switch
anyone changed the oil pressure switch, mine seems to be playing up.
cant find one on the parts drawwings, can i use one from another bike? or even a car,(they seem the same) or are they an Aprilia item.
anyone know how much they cost.
- loafersmate
cheers, got one from in moto (£10.37 inc P&P)
unfortunatly this turned out not to be the problem. wiring seems OK also.
problem is that oil low pressure light comes on at about 2000 rpm (which on mine is tickover until i get round to turning it down a bit.)
the problem started after i last serviced it, this included an oil and filter change.
I took the oil filter back out this AM, and it must had been fitted at a slight angle as it is a bit sqaushed on one side, not badly but i stuck a new one in and thought that maybe it.
took her for a spin, as it only happens when the oil is hot, and it seems a bit better, but is still doing it.
doesnt come on at tickover so much but does if you stick it in gear and drop the revs a bit with the clutch.
any ideas what maybe causing this, i have looked through old posts, but only thing that came up was something about a sticking pressure relief valve?
- loafersmate
Well sorry to state the obvious and risk insulting intelligence ... but I guess it has got enough oil in there .... as checked by the strange official Aprilia method?
Sorry if this is too obvious ... but the number of times I've had a problem and found it was something blindingly straightforward ....
EDIT .... and Kwackers has just beaten me to the post!
- HowardQ
Sorry Andy but accurately checking the oil level on a Falco is never somethingthat I would call "Blindingly Straightforward"D-Rider wrote:Well sorry to state the obvious and risk insulting intelligence ... but I guess it has got enough oil in there .... as checked by the strange official Aprilia method?
Yeah - it's a "sticky" on the Aprilia Technical pages:Fausto wrote:Isn't there some issue re the oil filter changing shape/size recently?
If so - is it at all possible that you have the wrong one and it isn't fitting properly ?
CLICK HERE
- loafersmate
If the switch is definitley ok, the oil pressure can only be too low if:
a, the pump cannot make enough pressure at low rpm, ie clearances are too big in the pump
b, there is a leak in the pressure side of the system,
c, the pressure relief valve is set too low or the spring has 'gone weak'
I can't see the filter being fitted incorrectly causing the problem unless it was blocking one of the galleries partially. The only way to know for sure is to get a low pressure guage plumbed into the oil pressure switch port, the thread is m10x1, and check it against the manual.
If you don't like it, don't look!
