#1
by Aladinsaneuk » Tue Jul 10, 2007 5:00 pm
just did an oil change, and have noticed I have a little clutch slip at the moment
I used 10/40 semi synthetic oil by the way
I do not recall any before the oil change - is the is slight clutch slip down to the oil change and will rectify it self after a few miles??
am welcome to any thoughts on this :)
#2
by fastasfcuk » Tue Jul 10, 2007 9:24 pm
allmost certainly the oil you've used alad,10w40 is to thin, a 15w50 is a better choice.
#3
by Aladinsaneuk » Tue Jul 10, 2007 9:28 pm
will have to source some - went to three "bike shops" yesterday and could not get any - will swop it over tomorrow after a trip to norwich
xrphil
- Track Day Addict
#4
by xrphil » Tue Jul 10, 2007 9:31 pm
took me a while to find 15/50, and even then seemed to get a small bit of slip when it was 1st changed. settled down quite quickly though.
#5
by fastasfcuk » Wed Jul 11, 2007 6:52 am
i use putoline comp 4 15w50, it claims to have anti slip properties and in 4k i've not had a problem.
#6
by Fausto » Wed Jul 11, 2007 5:26 pm
Pete, what make oil did you use?
May help anyone else making the same mistake (if indeed it is an oil issue)
Falco9
#7
by Falco9 » Wed Jul 11, 2007 7:08 pm
I used 10/40 for the entire time I had the Falco with no problems, but I did have the Barnett clutch in there for quite a while
F9
#8
by Aladinsaneuk » Wed Jul 11, 2007 8:42 pm
that was Putoline - I was trying to get the bike sorted prior to both the oxford run this week end and a possible dyno run
I have some 15/50 semi arriving tomorrow - will swop it over
(Will keep left over oil 10/40 flavour to top the wife's car up.... I know she has nfi where the 710 cap is)
falcomunky
#9
by falcomunky » Wed Jul 11, 2007 9:31 pm
Ive recently put some Silkolene FUCHs 15/50, (via MnP), and all is well so far...
Two is the magic number... ;)
#10
by Nooj » Fri Jul 13, 2007 9:24 pm
over filled it?
#11
by Aladinsaneuk » Sat Jul 14, 2007 6:56 am
swopped over to 15/50 from mobil, problem gone
(I did the run from norfolk to hampshire yesterday just to make certain!)
