Swingarm
Torsten
Swingarm
#1 Post by Torsten » Sat Nov 21, 2020 4:25 pm
Hi i want to fit songlesid swingarm to my 2002 aprilia falco what make will fit???
Torsten
Re: Swingarm
#2 Post by Torsten » Sat Nov 21, 2020 4:37 pm
What single arm swingarm will fit my 2002 falco
Re: Swingarm
#3 Post by mangocrazy » Sat Nov 21, 2020 7:03 pm
I have no idea if it's possible, but I'd have thought the obvious candidate from the Aprilia range would be a Futura single sided swingarm. Not sure if it's an aesthetic match, and it will need a fair amount of engineering to make it work. There is no SSSA that is a drop-in solution. Whatever you do will involve a lot of machining and fabrication and the result will be a bike that is heavier, won't handle as well and will probably be a bit of a pig's ear.
FalcoDaz
Re: Swingarm
#4 Post by FalcoDaz » Sun Nov 29, 2020 2:10 pm
So that's a good idea then :D :D :D
FalcoDaz
Re: Swingarm
#5 Post by FalcoDaz » Sun Nov 29, 2020 6:54 pm
