Yes, Griff's position on larger TBs for Falcos has caused some 'debate' shall we say. The CE TBs are 57mm,aren't they? That's quite a jump from standard. Which part(s) of the rev range do you most see the benefit/improvement?Falco Frank wrote: ↑Sun Oct 18, 2020 10:07 amI too want to do the Jet mod but might treat the bike to a full 'Griff' service next year, mine now has a Gabro chip, new Colin Edwards throttle bodies and carbon velocity stacks - good improvement even if Griff poo's on bigger bodies, I wont be changing back again.
