Holds hands up and admits to an error
(copied from my post on another forum - hammonds is a local place to us that has a ride in ride out tyre fitting service, that also does chain checks etc)
Went over to see the chaps at hammonds today, and had the tyres checked, wheels balanced and chain checked
First off - even though I had no vibration, the wheels were slightly out of balance - nothing major, but did need doing for peace of mind
Second - my chain was spot on - but, as Kev said, he had checked a bike yesterday that was wrong - the marks needed were 3 1/4 and 3 1/2 notches (Not the 3 1/2 on both sides!) - if left alone it would have shortened the life of the chain a fair amount
Finally - you live an learn. My aprilia manual has the tyre pressures listed in bar - 2.5 and 2.9 respectively. My own pressure gauge is in pounds so, i went on line and found a nice conversion utility that gave me what I thought was correct - 32 and 36 pound.
WRONG
it appears that there is a difference between USA/Canada pound per square inch and the UK measurement - I should have actually had something like 36 and 42. (Kev showed me some tyres that actually had the pressure guide on the side of them - and in big letters it said USA/Canada only
something maybe for us all to learn
Needless to say the bike felt a lot better - and I take back my niggle about conti tyres taking a while to warm up - now they are spot on from the off :)
WRONG
the manual does say what you have paul - but the official paperwork from bridgestone shows that their tyres should be at 36 and 42. Now I am on conti's but i thought it worth a try to see what happened so went with equivalent - all i can say is that wether or not I was wrong in my conversions, or made an error elsewhere, or the tires need a bit more in.... they sure are better handling now
Pirelli recommend 2.5 bar front and 2.9 bar rear for Diablos and Diablo Stradas on the Falco.
That's what I run and it feels pretty good (it's quite noticeable when the pressure drops off a little).
Pirelli
.... and here's a PSI / bar conversion table
Pressure Conversion
36psi / 42psi is about right.
Pirelli
Pressure Conversion
cheers andy
maybe that is one reason why the stock metzlers got such a bad review!
what tyres are you on paul - and perhaps try a little harder pressure? I never really complained about the handling, but i always said the conti's were average till warm - now I reckon that once they were at temperature, they were at the right pressure!
nod Lazarus - am sorry if it was not explained properly
I went by what the official aprilia owners manual said for the stock tyres
at the same time, it was brought to my attention that there is a difference between desired/intended pressures in the USA and europe
having done all that, there is a major thing - the official manual differs markedly from what the tyre manufacturers say they should have their tyres run at - and the difference is marked
hope that clarifies it a bit
IN SIMPLE TERMS - CHECK THE TYRE MANUFACTURERS GUIDELINES FOR TYRE PRESSURES PER BIKE
