Callipers swap
Pan
Callipers swap
#1 Post by Pan » Sun Jan 06, 2019 2:24 pm
Basically I’ve dropped a bollock! Bought some nice flashy Hell hoses for my falcuono conversion ( I know it’s frowned upon ) but it turns out they aren’t the right ones for my callipers :smt009 . My ones have the banjo bolt on top and the others that hose fit are at the side. I’ll attach some pics, do I buy more hoses or swap callipers ( always assuming the mounting bolt spacing is the same? )
My type :-
Other type:-
#2 Post by D-Rider » Sun Jan 06, 2019 10:44 pm
Top ones are 2-pad callipers as fitted to Falco and early Mille.
Bottom ones ate 4-pad callipers as filled to later mille (pre-radial) .... and retrofitted by some of us on our Falcos.
Pan
#3 Post by Pan » Sun Jan 06, 2019 11:31 pm
Cheers D rider, any noticeable improvement with the later brakes?
Mark
#4 Post by D-Rider » Tue Jan 08, 2019 3:43 pm
It was a while back I changed them and also fitted a radial master cylinder at the same time. From what I remember, there was more braking power (not that the standard setup was lacking) but there was also more "feel"
My Futura has the same brakes as the Falco originals (but smaller rotors). I think it confirms my recollection.
Not a vital mod by any means.
spiderwheels
#5 Post by spiderwheels » Wed Jan 09, 2019 8:16 am
One of my Falcos has the standard setup and the other has the 4-pad calipers with an Accossato radial master cylinder.
The 4-pad setup is certainly superior in terms of feel and requiring less effort.
As DR said the standard setup is sufficient but if I prefer the extra feel in tricky conditions or on crap roads.
Insert humourous comment here
#6 Post by fatboy » Wed Jan 09, 2019 7:26 pm
So you kept the trick one then Mr Spider !
spiderwheels
#7 Post by spiderwheels » Wed Jan 09, 2019 9:14 pm
fatboy wrote:So you kept the trick one then Mr Spider !
I'm going to make a best of both, though this may mean swapping the frames.
#8 Post by mangocrazy » Thu Jan 10, 2019 7:49 pm
spiderwheels wrote:The 4-pad setup is certainly superior in terms of feel and requiring less effort.
I agree - really like the extra bite and feel of the 4 pad calipers.
Greg
#9 Post by Greg » Thu Jan 10, 2019 11:00 pm
I've got a set of those to put on my Falcuono - yes I am proud of it! - but having had the experience of the foot-mashing stoppie power of the Falc's original calipers I'm wondering whether I really need to fit them ...
Pan
#10 Post by Pan » Thu Jan 10, 2019 11:09 pm
Greg, how far have you got with your falcuono?
Mark
Falco Frank
#11 Post by Falco Frank » Sat Jan 19, 2019 8:33 pm
Think I have a spare pair of gold 4-pad calipers if you want to change them out.
Cheers - Frank
Pan
#12 Post by Pan » Sat Jan 19, 2019 8:47 pm
I’m stuck trying to decide if I should swap callipers of just buy the correct hoses? But Pm me a price please Frank.
Mark
spiderwheels
#13 Post by spiderwheels » Sat Jan 19, 2019 8:52 pm
Pan wrote:I’m stuck trying to decide if I should swap callipers of just buy the correct hoses? But Pm me a price please Frank.
Mark
Could you not return the hoses for the correct ones?
Pan
#14 Post by Pan » Sat Jan 19, 2019 9:11 pm
No mate, it was my mistake but we live and learn!
Pan
#15 Post by Pan » Sat Jan 19, 2019 9:19 pm
