AIR SENSOR FALCO
Just Brian
AIR SENSOR FALCO
#1 Post by Just Brian » Mon Jul 16, 2018 8:38 pm
Hi can anyone tell me where its best to put the air sensor located in the right side air intake, As I have removed the fairing. I seen to remember someone on here saying to place it in the air box. At present its situated in a piece of tube under the clocks.
If it's not done today , there's always tomorrow.
Just Brian
#2 Post by Just Brian » Mon Jul 30, 2018 8:08 pm
look like nobody knows :smt009
#3 Post by D-Rider » Tue Jul 31, 2018 7:13 am
Sorry I don't know - mine is in the air tube in the fairing where it should be.
#4 Post by fatboy » Tue Jul 31, 2018 4:54 pm
See what works ?
It was right in the air scoop enjoying the wind across its little circuits, something similar may be OK !
Just Brian
#5 Post by Just Brian » Tue Jul 31, 2018 6:47 pm
Ok , Thanks for replying D rider and Fatboy , It's going in for a service tomorrow so will see how things go. Might confuse them a bit haha. :smt017
#6 Post by mangocrazy » Wed Aug 01, 2018 7:05 pm
It's worth finding out exactly what its function is. If it measure ambient air temperature (and I'm not sure if it does or not) it needs to be exposed to the air, but probably not in a howling gale. Find a similar location to the original would be the best advice I could give. I don't think in the airbox would qualify.
GregD-UK
Air Sensor
#7 Post by GregD-UK » Tue Aug 07, 2018 2:07 pm
Probably an NTC, Higher the temp lower the resistance back to the main board. Then the fuel is mixed via elektrikery…
By the way, Negative Temperature Coefficient (NTC) ok...
