lights / leds for dark/clear lenses
#1 Post by Aladinsaneuk » Thu Jun 07, 2007 3:57 pm
have had a quick look, and as i am going to be receiving a new shiny dark rear lens in the next week or so....
EXACTLY how do most people change the lights over?
a link to a suitable post would be great :)
Syltiz
Chaos Merchant
#2 Post by Syltiz » Thu Jun 07, 2007 4:10 pm
Are you fitting an LED board aka Nooj's lights or just changing the bulbs?
#3 Post by Aladinsaneuk » Thu Jun 07, 2007 4:51 pm
would like to assess both - in terms of fettling fun and bitch of a job'ness
initially something quick that just works, with a possible view to changing stuff come the winter
Lttlcheeze
#4 Post by Lttlcheeze » Thu Jun 07, 2007 6:14 pm
The first thing you have to do is change the bulbs to red bulbs that would allow you to use the clear or smoked lens.
You can upgrade to LED bulbs it is pretty easy just pull out your 1157 (type of bulb) and put in an 1157 LED.
On top of that you can buy a motorcycle specific tail light integrator, that will incorperate the turn signals into the left and right brake lights. I've seen them for anywhere between $50-$150. But you can buy one for a trailor that will do the same thing at just about any auto parts store for $5-$10.
Then from there you go custom LED or something nobody has thought of yet. Basically the possibilities are almost endless.
Bill
#5 Post by Aladinsaneuk » Thu Jun 07, 2007 8:28 pm
oo o- thanks
just what I needed to know - and i think I can have lots of fun with some of those :)
Falcoholic
#6 Post by Falcoholic » Fri Jun 08, 2007 8:43 am
I've ordered the 360 degree stop and tail jobs from here.
Not cheap at 25 beer vouchers for a pair but if they work I reckon they'll be the mutts dangly bits.
http://www.consumabulbs.com/files/allbu ... ?cat_id=13
The Delicate Sound of Thunder
#7 Post by HowardQ » Fri Jun 08, 2007 12:21 pm
Nice one Andy, I was just going to ask about those !!!
Howard
#8 Post by Kwackerz » Fri Jun 08, 2007 1:48 pm
http://ebook.maplin.co.uk/maplinlargeeb ... l?page=449
They do LED lights in maplins if thats of any use
paddyz1
#9 Post by paddyz1 » Fri Jun 08, 2007 6:24 pm
#10 Post by Fausto » Fri Jun 08, 2007 6:40 pm
Had a quick look at these and they look like single action bulbs. In other words NOT tail light/Brake bulbs.
I still haven't got round to getting LEDS for mine yet :smt009
falcomunky
#11 Post by falcomunky » Fri Jun 08, 2007 6:58 pm
Try here;
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=003
Where I got mine from, (and EEEPs n GregUKs), but they are cheaper now! :smt013
Oh just noticed; They are actually a tad more expensive than when I got some; That price is EACH, (I paid about £9 per pair as I recall). :smt001
Two is the magic number... ;)
#12 Post by Fausto » Sun Jun 10, 2007 6:26 pm
Cheers FM. I ordered some at the slightly more expensive price.
Am I the last to fit his/her new lens? Next w/e probably.
Anyone prepared to give a detailed walkthrough of this operation? I feel sure it will be far more fiddly than just undoing a couple of bolts - especially as my alarm is mounted right up there in front of the bulb access thingie.
#13 Post by Falcopops » Mon Jun 11, 2007 1:12 pm
Fausto wrote:I feel sure it will be far more fiddly than just undoing a couple of bolts
Yup, nothing is ever as simple as it should be.
IIRC You'll need to take of the rear plastic and the grab rail then undo the screws holding the two halves of the plastic surround together. pop the bulb holders out and remove the light pod and then 3 screw to take the back off the lens then refit. You'll need to be careful removing the rubber pads, they'll probably tear the bottom adhesive off, but a bit of double sisded tape will do the trick to hold them in place when you reassemble.
#14 Post by Fausto » Mon Jun 11, 2007 4:15 pm
Thanks FP.
Double sided sticky tape....... soooo Blue Peter :smt003
falcomunky
#15 Post by falcomunky » Mon Jun 11, 2007 9:14 pm
Dont forget the washing up liquid bottle and EMPTY cereal box as well... :smt003
Oh and what Falcopops said re; the bulb change. :smt004
