- Double World Champion
#1
by Gio » Mon Jun 04, 2007 8:46 pm
Are they the same as the Mille ones?
I need both of them, and there's none on fleabay
Pierre
#2
by Pierre » Mon Jun 04, 2007 10:30 pm
Brake is, gear bit isnt as milles is straight to shaft with no linkages like a falcos*
*waits to be corrected
#3
by D-Rider » Mon Jun 04, 2007 10:40 pm
Pierre wrote:Brake is, gear bit isnt as milles is straight to shaft with no linkages like a falcos*
That was my understanding too.
A quick visit to the Aprilia Yorkshire parts site will probably confirm, Gio.
sabestian
#4
by sabestian » Tue Jun 05, 2007 1:40 am
The Mille gear lever fitts but gives you GP pattern (1st gear up, uphifting-down) which is brilliant BTW.
As to brake lever I think the brake assembly is completely different and it wouldn't fit at all...
#5
by Gio » Tue Jun 05, 2007 12:02 pm
sabestian wrote:The Mille gear lever fitts but gives you GP pattern (1st gear up, uphifting-down) which is brilliant BTW.
If I was keeping the bike I'd go for the one up 5 down, I much prefer it.
Thanks for the help guys I'll take a deco round the 'prilia parts sites
#6
by HowardQ » Tue Jun 05, 2007 12:11 pm
Gio, you probably know you can get them here, but not cheap.
http://www.apriliayorkshire.co.uk/
This is where I had to get my rear brake lever from last December, never found one on Ebay or at various breakers.
Good luck.
TreeTops
#7
by TreeTops » Tue Jun 05, 2007 12:14 pm
Ive got both sets of foot controls in the garage for a falco... drop me a PM if you like.
#8
by Gio » Tue Jun 05, 2007 1:13 pm
Cheers Treetops PM sent
sabestian
#9
by sabestian » Tue Jun 05, 2007 6:18 pm
Don't want to play a vulture here but... Has any of your original gummy parts of levers survived? I mean the part of the lever that is in fact a screw dressed up in a rubber and that screws into an actual lever. Christ it must have a name
#10
by Gio » Tue Jun 05, 2007 7:59 pm
sabestian wrote:Don't want to play a vulture here but... Has any of your original gummy parts of levers survived? I mean the part of the lever that is in fact a screw dressed up in a rubber and that screws into an actual lever. Christ it must have a name
Do you mean the hydraulic bits?
#11
by Kwackerz » Tue Jun 05, 2007 8:02 pm
'Expensive' usually!
#13
by Gio » Tue Jun 05, 2007 8:56 pm
No then, mines sheared off to a tiny stump (part 11)
#14
by HowardQ » Wed Jun 06, 2007 12:32 am
The screwed pin bit is part of the lever and only comes with it, the lever cost me £49.41 (inc VAT) from local Aprilia dealer, rubber does not come with it, that's another £1.50. If you buy a new one soak it in v/hot water first or you'll never get it on. Be about as easy to got one off an existing lever I reckon.
Good luck
Howard.
sabestian
#15
by sabestian » Wed Jun 06, 2007 5:42 am
Thanks anyway, Gio.
HowardQ, that's the point. My lever itself is untouched, so I can't see the point in getting a new one. I've got a screw put in with some rubber over it at the moment. Fully functional but hurts my eyes ever time I see it.
If anyone has this bit laying around - let me know please. I need specifically the pivot (I've got the rubber).
BTW both sides (gear and brake lever thingies are the same).
