Oberon Clutch Slave cylinder
Hi, Looks like my one has started to leak. Does anyone know if replacing the seal is a d.i.y job. If so where can I find a replacement seal. I don't particularly want to endure the down time of sending it back to Oberon. Plus it would be nice to have a spare seal.
If you can get the thing apart then you may be able to read the seal number which identifies its size/ type.
If thats the case then look up specialist seal supplier
www.simplybearings.co.uk
or similar
or similar
