Falco Frank
#1
by Falco Frank » Mon Apr 25, 2016 12:47 pm
- Midnight Rider
#2
by Dalemac » Mon Apr 25, 2016 4:10 pm
Note that the rear axle nut is 90nm and not 120nm as specified in the manual. 120nm may damage the wheel spacers.
#3
by fatboy » Mon Apr 25, 2016 5:34 pm
Yep, thats right.
The torque value was reduced to 90 nm after the 120 nm value could cause stress and strain to rear wheel bearings.
Having a rear wheel bearing fail on the move is as much fun as a rear tyre blow out, and as bloody dangerous
Falco Frank
#4
by Falco Frank » Mon Apr 25, 2016 6:42 pm
Thanks for the Info - I didnt realise that change!
120Nm = 88.5 lbs/ft which does not seem too high to me but someone rounded a rear nut off on my Falco in the dim distant past.
I tried looking for updates to the service manual and a rumored full new revision but couldnt find anything newer than on Martin's website???
#5
by D-Rider » Mon Apr 25, 2016 6:58 pm
Griff recommends 100 Nm
Aprilia does specify 120Nm but a number of bearing failures has led Griff to recommend 100 Nm.
