Clutch master cylinder needed....
Seems I've found the cause of my random neutral selection problem, today noticed fluid starting to weep from where the plastic elbow pushes into the top seal on the assembly.
Does an RSV one fit ?
Does anyone have one to flog ?
How sodding typical that the master would go just after I'd replaced the slave and entire clutch plate stack
Well I've seen a few on 'that auction site'for silly money but also a Tuono one(2008) that looks identical for sensible money.
My line of thinking is they all use a number of Brembo parts so historically it would make sense to fit the same components across the range ?
The one rebuild kit I have found ( and can't verify is the right one ) is £119.93 plus post.
A dealer , Kickstart Mc's in Port Talbot told me it is not an available spare.
I'm satisfied that they know their shit as the did all the rebuild work for the Haynes RSV manual.
Second hand spare it will have to be for now
Well after carefully looking at the pics of the 08 Tuono one I bought it in the hope that it would fit....
And it does !
The only things that differ between the Falc and Tuono master cyl are the resevior stay bracket is shorter on the falco and you will also need to re fit the falco bar clamp bracket as it has the tapping to secure the upper of the two bolts that secure the fast idle cable/lever housing.
Just over an hour from start to finish including bleeding up !
Well earned beer for me
And it does !
