........ where is the earth fixing point for the negative battery terminal.
Been having some slow starter motor behavior recently.
2nd question - starting routine has changed in the last few months. She no longer wants to start on the fast idle and I have to use half throttle to fire her up then settle her on the fast idle. Is it anything to worry about?
Thanks peeps.
I should know this, but......
Re: I should know this, but......
I would remove the power lead from the starter and clean the terminals Dave.DavShill wrote:........ where is the earth fixing point for the negative battery terminal.
Thanks peeps.
When cleaned up cover the terminl with grease.
Make sure the threads on thee terminal are clean before removing the bolt, if not you may break the plastic lug inside the starter?
