Engine swap advice
Engine swap advice
Hi, I'm looking at swapping my 120K Kilometer Falco motor for a 40K K. 2002 RSV motor. (Thanks Pete for the heads up)
Any pointers, hits, tricks or things to watch out for?
Is it likely to be a big valve head? How do you tell without taking the heads off?
I believe that I'll have to reverese the gearshift linkage (go below rather than over the top? or put on a lever direst to the gearbox shaft?)
Falco headers fit?
Oil cooler?
Throttle bodies ok?
Falco headers fit?
Oil cooler?
Throttle bodies ok?
- Falcopops
AFAIK the headers and the throttle bodies will be a direct fit.
One thing I know for certain is that the coolant line setup is different, I was looking to get a set of samco silicon hoses and they were subtly different around the thermostat/water pump area. Dunno if that'll cause any significant issues.
I'm pretty sure this has been done a number of times and a mechanical genius like yourself should have few problems
As you have an early falco, I think that the radiator and oil cooler plumbing will be a straight fit from falco to Mille engine
The falco oil tank would therefore have to be used
If you end up with the Mille oil tank the headers will still fit
- GregD-UK
Hi all.
you need the ecu and clocks to marry up with the engine! Otherwise the tucker won't start. Pierre found out this to his cost.He also managed to squeeze the anglular swingarm in with a bit ofcutting on the battery box. He fitted one of those slimline batteries anyway...
Enjoy the swop, would fit the falco cooling system and oil tank. Unless you change the exhaust setup...
I now have the motor and according to the engine number it should have the larger valves. it didn't come with oil tank or rads and is also missing a couple of sensors. It did come with throttle bodies though.
It didn't come with ECU (is that the same as the chip?) I have a standard Falco and a Gabro mapped to Falco's evo air box and RC can configuration. I would have thought it would at least run with the Gabro chip and other bits and pieces brought across. GregD-UK or anyone else for that matter, do you know what is different about the ECU?
I’spose I can talk to Griff next week and see what he says, I did talk with Lewis last week when I rang and Griff was out, he implied it should be a strait swap.
One niggle sofar is that it has what looks like a small Jd weld patch on the rear crankcase just beneath where the rear header would exit. Sign of some one getting frustrated in an earlier life...
Iirc the Mille and falco clocks are inter changeable
If it comes with the Gabri chip, then I assume that will work though you may well need to consider changing the exhaust - your falco pipes and headers will still fit, as indeed should the oil tank
I guess you need to get the engine in the frame and see :)
