Falco parts for sale.
#1 Post by blinkey501 » Fri Jan 01, 2016 3:35 pm
Hi folks I have some panels for sale which some are straight with minimal marks.
But someone has not rubbed them down properly before painting over the top.
I am open offers, but to have bodywork that is not cracked or broken is worth having.
So I have a belly pan which is a skidmarx item. But as I say needs rubbing down and painting...But not cracked.
Rear sub frame...
Screen. Corner is missing, But anyone with a falcuono could easily shape this. The rest of the screen is tidy.
Side panels
Finally a clear lens with LED back plate.
But I would like £100 plus a fiver delivery for this.
The headlight lugs have broken, but still with the light unit, so can be glued back on.
Thanks
squadron Nero
#2 Post by squadron Nero » Fri Jan 01, 2016 4:53 pm
How much for the rear light lenses jay
#3 Post by blinkey501 » Fri Jan 01, 2016 6:57 pm
squadron Nero wrote:How much for the rear light lenses jay
Messaged on fb karl.
Midnight Rider
#4 Post by Dalemac » Fri Jan 01, 2016 8:38 pm
How much for the side fairings Jay?
#5 Post by blinkey501 » Fri Jan 01, 2016 8:40 pm
Dalemac wrote:How much for the side fairings Jay?
£10 each mate please
#6 Post by mangocrazy » Fri Jan 01, 2016 11:26 pm
Hi Jay, how much for the Skidmarx belly pan?
Midnight Rider
#7 Post by Dalemac » Fri Jan 01, 2016 11:34 pm
Awesome, I'll have them, then I can finally get my mille bellypan sorted.
PM me your PayPal info and I'll get it sorted.
Oh, might be interested in the tank too, depending on the price.
#8 Post by blinkey501 » Sat Jan 02, 2016 10:24 am
mangocrazy wrote:Hi Jay, how much for the Skidmarx belly pan?
They normally do 80 quid second hand graham?
But due to needing rubbing down, I would do it for sixty.
There is no mounting kit.
Skidmarx pans are now 130 quid new + fitting kit
#9 Post by blinkey501 » Sat Jan 02, 2016 10:27 am
Tank you can have 50 quid mate? I think this is about right for an undamaged tank.
The tank will need rubbing down? But if you have a painting project in mind this wouldn't be an issue.
The tank came to me with no pump.
I don't do paypal though, so we will need to meet up.
#10 Post by mangocrazy » Sat Jan 02, 2016 1:15 pm
OK, cheers Jay - deal. I take it the fitting kit for the rear is just a couple of angle brackets? How does it fit at the front?
Midnight Rider
#11 Post by Dalemac » Sat Jan 02, 2016 1:38 pm
OK, I'll take the tank as well.
No problem, are you venturing into Lincoln at any point in the near future?
#12 Post by blinkey501 » Sat Jan 02, 2016 1:58 pm
Not sure mate.
Pm me your phone number :smt002
#13 Post by blinkey501 » Sat Jan 02, 2016 2:00 pm
The front bolts up to the locating points which you will unscrew when removing the aprilia unit?
You can buy the fitting kit direct from skidmarx if required.
#14 Post by mangocrazy » Sat Jan 02, 2016 5:42 pm
blinkey501 wrote:The front bolts up to the locating points which you will unscrew when removing the aprilia unit?
Ah yes, of course - silly me. I knew that... :)
blinkey501 wrote:You can buy the fitting kit direct from skidmarx if required.
Yes. That did also occur to me shortly after I posted... Put it down to the delayed effects of NYE...
#15 Post by blinkey501 » Sat Jan 02, 2016 7:01 pm
:smt001
