Steering damper
squadron Nero
Steering damper
#1 Post by squadron Nero » Fri Jul 24, 2015 10:25 pm
Does anybody know if the ohlins damper from an RSVR will fit a falco? Will I need some fitting brackets to go with it? What's involved in getting one to fit?
Thanks lads
#2 Post by D-Rider » Sat Jul 25, 2015 7:31 am
I believe it does.
Others will have to inform you of the details - I've never bothered to fit one as I've never felt the Falco needed one.
squadron Nero
#3 Post by squadron Nero » Sat Jul 25, 2015 9:19 am
Thanks Andy.
The problem I'm finding is under mid range acceleration in 1st or 2nd and sometimes even 3rd the front goes very light and skittish. I'm worried if I hit a bump or cats eye while overtaking it'll send me into a huge tank slapper. Hopefully the damper will reduce the chance of this. Under hard acceleration it doesn't matter as the front will lift cleanly off the ground.
#4 Post by HisNibbs » Sat Jul 25, 2015 10:30 am
Fitted Ohlins to mine. Could get the bars to wag around occasionally but it has only ever once gone unstable. That was just maintaing speed in a very bumpy straight line stretch of local back road.
Best if you can get the mounting bolts/kit with it. I just used set screws. Also lock tight to yokes as there is not much thread in contact, otherwise they can work loose.
#5 Post by Aladinsaneuk » Sat Jul 25, 2015 9:32 pm
They are, imho , necessary with bars over the triple
Make sure you buy one with the fitting kit
wayno
#6 Post by wayno » Wed Jul 29, 2015 10:41 am
Not sure about Ohlins, but I would assume so as I can confirm the later silver sachs ones fit the Falco fine (I have one fitted to mine)
