front brake master cylinder
bigearsbilly
#1 Post by bigearsbilly » Mon Mar 30, 2015 3:06 pm
I know there's lots of stuff here but I can't work out what is current and what is not.
I have a leaky one, on an '02 Falco.
I gather you can't get a service kit.
Can I get a millie or tuono master on ebay as a replacement brake master cylinder?
Or is there any Ducati method maybe?
thanks.
#2 Post by Aladinsaneuk » Mon Mar 30, 2015 3:54 pm
Mille one is the same
Iirc there is a Ducati part that is slightly cheaper new
bigearsbilly
#3 Post by bigearsbilly » Tue Mar 31, 2015 7:22 am
ta very muchly.
I was wondering has anyone replaced the front brake master and lever with one from a blade or a gixxer or similar? I wonder if it would fit OK.
At least one could get a seal kit for it.
bigearsbilly
#4 Post by bigearsbilly » Tue Mar 31, 2015 7:58 am
Seen an RS250 master that looks exactly like the Falco one.
Anyone?
#5 Post by D-Rider » Tue Mar 31, 2015 9:36 am
bigearsbilly wrote:ta very muchly.
Go for radial masters - I've a brembo racing brake master and mango has the Aprilia one from (I think) an RSVR.
The one Mango has fits easier.
We've also got the radial clutch master cylinders.
If you're changing, I'd say they are worth considering.
#6 Post by mangocrazy » Tue Mar 31, 2015 4:32 pm
If you go down the radial route, be aware that the take-off point for the brake hose is underneath the master cylinder (and will almost certainly require a new hose) and the depth of the m/cyl is greater; i.e. there is less clearance between lever and fairing/clocks than previously.
