An old topic I know but need some clarity before I start cutting wires.
I have a 54 plate Falco originally from dk's in staffs. I believe its an import as at mot time the tester regularly puts a piece of tape on the headlight to get it through the beam test. Should I assume its restricted and remove the plate under the airbox and cut the correct wire ??
Help
The geocities link no longer works . A link to Instructions and or pics would be great...
falco derestriction
falco derestriction
Back on an Aprilia, where i belong
- flatlander
http://home.comcast.net/~sl_mille/derestrict.html
https://www.ridersite.com/viewtopic.ph ... fe1eff248a
Any use?
Any use?
