Parts required:
Gen 2 57mm TB's
Gen 2 Tuono Velocity stack x 2 ($1.49 each from AF1 $17 postage or £15 plus postage in the UK) AP8106876
Velocity stack o rings x 2 AP8144581
Bosch EV1 to Denso connectors x 2
Vacuum blank off hose or caps
Dremmel or Colin Edwards lower airbox AP8168761
Fuel line hose clamps
Aluminium crush washer x 2 HONDA part #94109-12000
Forza or Gabro chip would be recommended unless you get a PC map.
I did this job with the fuel reserve light illuminated, as it makes for a lighter tank and less spillage.
First job is to remove the airbox completely.
Discount all vacuum lines, breathers and electrical connectors to the TB's on the bike.
Undo the throttle cables, fast idle and idle adjustment cables.
Undo the 2 circlips that connect the intake boots to each cylinder.
Undo the rear fuel tank bolts.
Disconnect the 3 pin socket that connects the fuel pump electrics. This socket is located just to the left of the battery when looking from the rear of the bike.
Disconnect the water drain pipes from the base of the tank.
Remove the tank WITH the TB's attached.
Once you have the tank and TB's removed, place them somewhere so the tankis on it's nose and the TB's are above the tank. This will help reduce fuel spillage considerably.
If you can swap the idle adjuster plate assembly from the old to the new, then it is advisable otherwise you will have no fast idle. I was unable to do this so will be using the idle adjuster for cold starts. 2 complete turns will give enough for cold starting. (Tried and tested)
Ensure that you have some new aluminium crush washers. Remove the banjo bolt and 2 old washers. Fit the 2 new washers andbanjo bolt to the fuel line and secure it to the new TB. Undo the fuel return line clamp. This will more than likely be the OEM no usable clamp. Fit a new clamp and then fit to the new TB and secure correctly.
Fit blanking caps to the 2 vacuum outlets that would run to the Gen 2 airbox stepper motor. I used a Gen 2 hose and doubled it up, but vacuum caps will suffice. Remove the blanking plug from the forward right vacuum point on the old TB's and place it on the rear right vacuum point on the new TB. This is because the hose that goes to the PPC will not reach.
Fit the new TB to the engine along with the fuel tank and secure all the clamps and fittings correctly. Ensure that the 2 small hoses on the left side are connected to the air sensor, and that you fit your wiring loom adapters.
Refit the throttle cables, fast idle and idle adjust cables. (Good time to clean and service them).
If you have the Edwards lower box, then just fit the velocity stacks and rebuild the airbox as normal. If not, then you will have to get the dremmel out and slightly widen the OEM holes out to allow fitting of the 57mm stacks. Clean up all the plastic swarf, test and adjust as necessary before rebuilding the airbox. Ensure that you have the o rings fitted as well. The Gen 2 o rings are a wider diameter, but also slightly thinner.
Rebuild everything else, check for fuel leaks and fire her up :)
I take no responsibility if you get it wrong
