probably a stupid question
I bought some chainlube that looked all singing/dancing, dry lube with PTFE.
I hold my hands up and admit it was a late evening weekend purchase,so when the 3 cans arrived I realized I did not check that it is labelled suitable for use with 'o'ring chains.
It does not say so on the tin so would I be even more foolish to use it ?
Before I went back to shaft drive (so superior, no faffing around with greasy stuff, no adjusting) I used Wurth dry chain lube, as I knew a Wurth rep through work (got it at trade price). I asked the same question, & was told by Wurth it wouldn't adversely affect O or X rings.
Thanks Mart, its from Denmark, super super eco stuff, uses CO2 as propellant so you get more product/less propellant for your bucks.
It's probably so much more advanced than the crap we buy here, the Danes would see it as advertising to the retarded ( that its OK for 'o,ring chains as anything less is in the dark ages).
Nice to hear you are no longer smug about your shaft drive
- squadron Nero
- squadron Nero
Worked for me too - even though its for a belgian website (.be) it seems to redirect.
Pulling the URL from the Youtube page gives this:
https://www.youtube.com/watch?v=1oXxheE ... e=youtu.be
Maybe that'll work for you.
