Barnett clutch
Barnett clutch
It arrived t''other day,instructions say Never use automotive oils as they do not meet specific and special requirements of motorcycle engines, clutches and transmissions....
Does this mean in Twinkie the kid country they have different oil specifications to us or do kevlar friction plates have special needs ?
Left it too late to ring Opie oils today, any of you guys able to shed light on this one ?
Cheers Paul
Cheers Paul
- Firestarter
- Twisted Firestarter
Sure - car oils aren't suitable for bikes - especially as their friction modifiers often play havoc with clutches ..... but automotive oils include oils for both cars and bikes and I really can't understand why it is suggested that motorcycle oils are unsuitable.Firestarter wrote:Car oils aren't suitable for motorbike engines. The stresses in the engine leads to breakdown of car oils, bike oils are specially formulated. Don't think its an international thing they're referring to
.... now if it said "automobile oils", that would be a completely different kettle of fish ....
I thought fish usually came in Olive Oil ....mangocrazy wrote:A kettle of fish, presumably fried in 10W50 semi-synthetic oil... ?D-Rider wrote:.... now if it said "automobile oils", that would be a completely different kettle of fish ....
.... though maybe Kettle cooked fish requires a different oil
Leopard's fanny batter, or monkey spunk, could work
http://viz.co.uk/mickeys-monkey-spunk-moped/
http://viz.co.uk/mickeys-monkey-spunk-moped-2/
- Firestarter
Fair enough. Would imagine it's more a translation/terminology issue, rather than a "don't use bike oils" issue.D-Rider wrote:.... now if it said "automobile oils", that would be a completely different kettle of fish ....
As Falcopops said, I'd always understood it to be "soak it in what the bike runs on". Not sure that Mart's suggestion applies...
Well the advice for soaking the plates makes as little sense as the oil choiceFirestarter wrote:Fair enough. Would imagine it's more a translation/terminology issue, rather than a "don't use bike oils" issue.D-Rider wrote:.... now if it said "automobile oils", that would be a completely different kettle of fish ....
'Soak friction plates for 1 to 3 mins, wipe dry with lint free cloth'
Why dry frictions when they will be living in the bloody stuff ?
Thanks Mart but Opie don't sell that stuff !
fatboy wrote:Maybe to stop the oil dribbling down your sleeve when you're fitting it? :)Firestarter wrote:Well the advice for soaking the plates makes as little sense as the oil choiceD-Rider wrote:.... now if it said "automobile oils", that would be a completely different kettle of fish ....
How is the Barnett clutch? If I have to replace my diaphragm I may do the whole clutch while I'm at it...
Insert humourous comment here
They used to be a popular mod when Falco ownership was dominated by the earliest models that were more prone to clutch slip.spiderwheels wrote:
I have no direct experience of one but what I have picked up is:
- * They tend to be much heavier than standard - some people improve this a bit by fitting half the Barnett springs and half the standard Aprilia springs.
* There have been issues with the Barnett pack not fitting properly - being too thick. People that have taken this up with Barnett have usually been sent a thinner steel to replace one in the pack
With regard to EBC frictions, I have a complete set doing nothing because they don't bloody well fit, the overall plate thickness is to great, the assembled stack sits proud of the clutch hub and you end up with an unusable bike.
This can be remedied by reducing the number of frictions from 9 to 8 and you lose 10% of your clutch efficiency, not what you want.
Look on AF1, I am not alone in having problems with EBC frictions.
I researched the Barnett problems, caused by the steels, they rectified this in 2010 and supplied free of charge new steels to anyone with an earlier set.
Again look on AF1.
I will fit the Barnett next week and report back.
Please note, I'm not anti EBC,'they got their sums wrong and you will simply buy yourself problems
Again look on AF1.
