QR seat bolts!
ginge
QR seat bolts!
#1 Post by ginge » Thu Jan 08, 2015 11:33 am
Ive read on here befroe (but cant seem to find it!) about bolts for the seat which could be undone by hand, some kind of Dzus fastening system maybe?
Does anyone have these/know where I can get them as it's a pain in the arse getting the seat off?
Thanks for any help.
Falco Frank
#2 Post by Falco Frank » Thu Jan 08, 2015 12:24 pm
I feel your pain!
Pushing the seat foam right in and using a long T-bar made life easier but,
Using a cordless screwdriver and an extension with the right hex bit makes it easier still (No use on the road I appreciate!)
wayno
#3 Post by wayno » Thu Jan 08, 2015 1:10 pm
you may be thinking of the AF1 quick release seat pins, I made a massive batch of them, but don't have any left now.
Personally I find them more difficult than the screws, but they do remove the risk of cross threading the screws.
http://www.af1racing.com/store/Scripts/ ... oduct=1481
#4 Post by randomsquid » Thu Jan 08, 2015 6:44 pm
I bought some of the ones that Wayno made and have found them useful especially as one of my screw holes had been cross threaded and looked to be on the way out.
When they are in the right place to keep the seat tight there isn't much room to manipulate the clips because of the lip around hole under the saddle.
With practice, a bit of wire to stop the clips disappearing and the pointy end of a tea spoon (yes really) to pop the clips in and out I find them convenient.
#5 Post by flatlander » Thu Jan 08, 2015 7:15 pm
Unsurprisingly I've got some I've never used
#6 Post by Aladinsaneuk » Thu Jan 08, 2015 9:14 pm
teaspoon??
i use the gerber MAN tool - the pliers attachment.....
agree with the wire ... key
#7 Post by Falcopops » Fri Jan 09, 2015 10:44 am
made my own set many years ago and use R clips with the ends bent up so I can get them on and off by hand with ease
squadron Nero
#8 Post by squadron Nero » Fri Jan 09, 2015 2:13 pm
Do you lot need to get under your seat that much? I've only removed mine twice so I could lift the tank to get to the airfilter housing. If I want to charge the battery I've just fed the optimate lead up to under the pillion seat / cowl.
What are you lot going in there for?
#9 Post by randomsquid » Fri Jan 09, 2015 6:02 pm
Aladinsaneuk wrote:teaspoon??
Well I have a Brown Falco and not one of those dodgy black ones like you.
I often don't have tools on hand, manly versions or not, I'm never far from a teaspoon though.
And in answer to Karl's what am I doing under there question, to hook up my trickle charger. Works much better than the optimate but I think that has a duff lead.
#10 Post by fatboy » Sat Jan 10, 2015 7:44 pm
I have a set of the Way no pins fitted, I don't struggle trying to fit 'r'clips cos I don't have any and don't need any cos I need to push the tail unit outwards to get the rounded bolt areas of the seat base to fit on subframe, so stop being senile old women
ginge
#11 Post by ginge » Sun Jan 11, 2015 9:29 pm
Been taking my seat off alot as I dont use my bike much so remove the battery, however I used it and now the relay has gone. I also like tinkering/giving myself problems to tinker further :smt003 .
Thanks for the ideas. Think I may try and drill through the subframeand make some sort of proper QR release system. Will let you know how this goes.
