Cans can or cant.
Obiwan Kenobi
Cans can or cant.
#1 Post by Obiwan Kenobi » Wed Jan 07, 2015 4:45 pm
I have some aftermarket cans on the Falco from when I purchased it.
Is there any way of checking easily if the fuelling etc has been fiddled with to adjust it to suit the cans by the previous owner?
Bike runs fine, but just wondering if any adjustment is usually necessary when just sticking on some cans on the Falco.
Ta.
These are not the Droids you're looking for...
Re: Cans can or cant.
#2 Post by blinkey501 » Wed Jan 07, 2015 6:44 pm
Obiwan Kenobi wrote:I have some aftermarket cans on the Falco from when I purchased it.
Ta.
The fuelling is not generally a problem with aftermarket cans.
Some manufacturers supply the cans with a chip.
Some don't.
It is only when you start modding the airbox etc that you might want to think about a chip for your set up.
You will need the right chip for your set up if you go down this route. Don't just buy any chip as this could cause over fuelling.
Finally. Some have fitted a Gabro chip to their falco, for a personal thing and it makes things run smoother.
Its up to you what route you want to go down?
Hope this helps.
#3 Post by flatlander » Wed Jan 07, 2015 7:40 pm
What he said but unlikely as it is not to have been done might be worth checking the wire has been cut to the existing chip and if the lEVU looks like it had been opened then worth checking if it has already been chipped.
#4 Post by fatboy » Wed Jan 07, 2015 7:58 pm
'Open' cans can cause slightly hotter running but as others have said EPROM chips compensate, if the bike runs fine then I guess you don't got a problem.
Forza and Gabro chips provide a lot smoother running than standard EPROM,tick over is also more reliable.
Very easy to pop out ecu and only 4 small screws to open up ecu, if I'll is standard one of the screws will have a blob of sealer on it
Obiwan Kenobi
#5 Post by Obiwan Kenobi » Thu Jan 08, 2015 10:09 am
Ok, thanks, will have a look at the ECU then.
Like I said, bike runs fine, I just like to know whats been done to it, if anything. More for piece of mind, plus if I want to change anything in the future I will know from what point I am starting.
#6 Post by mangocrazy » Thu Jan 08, 2015 9:57 pm
Gabro does chips with 2 maps on them, switchable by the derestriction lead to the CPU (normally snipped to derestrict). On the blue Falco I had the 'restricted' map set up for standard plus Fuel cans, and the 'derestricted' map set up standard plus Fuel cans plus modified airbox. I haven't done any airbox mods yet, so am still on the 'restricted' map, but can say that the Gabro chip has smoothed out the power delivery no end, and also gives a very nice boost to the mid range. Seems to pick up noticeably faster as well.
