Questions
squadron Nero
Questions
#1 Post by squadron Nero » Mon Dec 29, 2014 4:11 pm
Been playing with the Falco today. Got my indicators fitted. As they are led I have four resistors to fit. I fitted the rear two with resisters and the were flashing correctly but the front when with the resisters were flashing way too quick so I tried it without and they are flashing at normal speed.nothing to worry about as there is no problem just thought it was weird.???
Secondly, I took my front sprocket off and on each side is like a large rubber washer(?) I can't see that it does anything and the new one doesn't have any. Should I take them off the old one and put them on the new? They seem well stuck on as if they were glued on at the point of manufacture.
#2 Post by flatlander » Mon Dec 29, 2014 6:40 pm
As you will remember Karl mark ;) I am about as spanner handy as a chocolate fire guard but I can imagine that the washers may be for absorbing movement ?? Bit like when you fit a car stereo cd changer to stop the disks jumping??
#3 Post by fatboy » Mon Dec 29, 2014 7:39 pm
With regard to the indicators, electricity is witchcraft, some on here are frighteningly versed in that dark art and may be along to proffer spells/reccomend sacrificial offerings.
As to the sprocket, look at Yorks Aprilia parts diagram,see if it shows them washers, mine works fine without
Re: Questions
#4 Post by blinkey501 » Mon Dec 29, 2014 8:29 pm
squadron Nero wrote:Been playing with the Falco today. Got my indicators fitted. As they are led I have four resistors to fit. I fitted the rear two with resisters and the were flashing correctly but the front when with the resisters were flashing way too quick so I tried it without and they are flashing at normal speed.nothing to worry about as there is no problem just thought it was weird.???
The indicators....That's normal to have a resistor on each side.
I made the same mistake and have two spares in the garage. :smt120
The front sprocket rubbers seem unusual.
I have fitted around five front sprockets to different aprilia's and never known this before.
But I can't see that it will do any harm if already fitted.
Shetland Woody
#5 Post by Shetland Woody » Mon Dec 29, 2014 11:59 pm
The rubber washers are normal, mine had them. Replace the sprocket and forget about the rubber washers. Jobs done.
squadron Nero
#6 Post by squadron Nero » Tue Dec 30, 2014 2:40 pm
Cheers lads. I was going to crack on with it all today but it's just too damn cold. My little fan heater gave up yesterday and I just couldn't face another day frozen in the garage.
